[GRASS-user] g.proj fails on winGRASS trunk with AIG/Arc/Info Binary Grid input
Rich Shepard
rshepard at appl-ecosys.com
Tue Jun 12 08:10:06 PDT 2018
On Tue, 12 Jun 2018, Markus Metz wrote:
> as of r72802, it should be possible to create a location from the data, and
> the projection check should work.
Markus,
I've not had an issue with creating a location, only importing the data.
> About valid values only along the edges, that's a different issue, most
> probably there is nothing else in the input data. The data provider would
> know if this is correct.
The other data, highest_hits, has the same problem. I'll download the data
again.
Rich
