[GRASS-user] problem
    hindo kush
    hindokush12 at gmail.com
    Sat Jun 16 14:01:49 PDT 2018
 Yeah i have set it as band 10 g.region raster=band10
Regards
On Sat, 16 Jun 2018, 23:59 Andrea Balotti, <balotti.and at gmail.com> wrote:
> Hi,
> first of all, have you set the region?
> Andrea
> Il giorno sab, 16/06/2018 alle 12.47 +0300, hindo kush ha scritto:
> All,
> While calculating Net Radiation i have to run the r.sun module and i did
> exactly what it was in the manual but the problem is this that i don't get
> any output any hint!!!
> (Sat Jun 16 12:39:45 2018)
> r.sun elevation=Dem at PERMANENT aspect=aspec at PERMANENT slope=slp at PERMANENT
> albedo=Albedo at PERMANENT lat=latmp at PERMANENT long=longmp at PERMANENT
> incidout=IRdAnM1 beam_rad=BIrdM1 diff_rad=DIrdM1 refl_rad=GrIrdM1
> glob_rad=GIrdM1 day=207 time=6
> Number of threads <1>
> Mode 1: instantaneous solar incidence angle & irradiance using a set local
> time
> Using Linke constant: 3.000000
> Using albedo map <Albedo at PERMANENT>
> Using slope map <slp at PERMANENT>
> Using aspect map <aspec at PERMANENT>
> (Sat Jun 16 12:39:53 2018) Command finished (8 sec)
> GRASS 4.1
> windows 64bit
> 16Gp Ram
> kindly see the attached picture as well
> grass-user mailing listgrass-user at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180617/b21f61eb/attachment.html>
