[GRASS-user] problem
Andrea Balotti
balotti.and at gmail.com
Sat Jun 16 14:52:26 PDT 2018
Hi,I suppose your raster "band10" overlap with rasters (Dem, aspec,
etc.) you use as input for r.sun otherwise you are trying to read
information from input rasters over an area where they have nodata.
Anyway, I tested on NC sample location but r.sun seems to work fine
also if I have not set albedo/lat/long rasters. I get always output
files, and empty only when are supposed to be (midnight for example).
Here the code I used:r.sun elevation=elevation at PERMANENT aspect=asp at PE
RMANENT slope=slo at PERMANENT incidout=out.beam beam_rad=out.direct
glob_rad=out.global day=207 time=6
Regards,Andrea
Il giorno dom, 17/06/2018 alle 00.01 +0300, hindo kush ha scritto:
> Yeah i have set it as band 10 g.region raster=band10Regards
> On Sat, 16 Jun 2018, 23:59 Andrea Balotti, <balotti.and at gmail.com>
> wrote:
> > Hi,first of all, have you set the region?
> > Andrea
> > Il giorno sab, 16/06/2018 alle 12.47 +0300, hindo kush ha scritto:
> > > All,While calculating Net Radiation i have to run the r.sun
> > > module and i did exactly what it was in the manual but the
> > > problem is this that i don't get any output any hint!!!
> > > (Sat Jun 16 12:39:45 2018)
> > > r.sun elevation=Dem at PERMANENT aspect=aspec at PERMANENT slope=slp at PE
> > > RMANENT albedo=Albedo at PERMANENT lat=latmp at PERMANENT long=longmp at P
> > > ERMANENT incidout=IRdAnM1 beam_rad=BIrdM1 diff_rad=DIrdM1
> > > refl_rad=GrIrdM1 glob_rad=GIrdM1 day=207 time=6
> > > Number of threads <1>
> > > Mode 1: instantaneous solar incidence angle & irradiance using a
> > > set local time
> > > Using Linke constant: 3.000000
> > > Using albedo map <Albedo at PERMANENT>
> > > Using slope map <slp at PERMANENT>
> > > Using aspect map <aspec at PERMANENT>
> > > (Sat Jun 16 12:39:53 2018) Command finished (8 sec)
> > > GRASS 4.1
> > > windows 64bit
> > > 16Gp Ram
> > > kindly see the attached picture as well
> > > _______________________________________________
> > > grass-user mailing list
> > > grass-user at lists.osgeo.org
> > > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180616/ae435643/attachment.html>
