[GRASS-user] question on i.nightlights.intercalibration code
Veronica Andreo veroandreo at gmail.com
Thu Jun 21 08:12:35 PDT 2018
Hi Gabriel,
Are you using Windows? I think you cannot use g.list inside a command as we
do in Linux. Solution would be to first get the list of comma separated map
names and then paste it in the i.nightlights command.
HTH,
Vero
El jue., 21 jun. 2018 11:05, Gabriel Cotlier <gabiklm01 at gmail.com> escribió:
> I have tried to run i.i.nightlights.intercalibration on the command line
> and got the following error:
> What could be happening?
> Thanks a lot
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180621/b0b0f657/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180621/b0b0f657/attachment-0001.png>
