[GRASS-user] question on i.nightlights.intercalibration code
Gabriel Cotlier gabiklm01 at gmail.com
Thu Jun 21 09:33:33 PDT 2018
Hello Vero,
Thanks a lot for your response.
I have tried that with no results, with the error in the image bellow:
On Thu, Jun 21, 2018 at 12:12 PM, Veronica Andreo <veroandreo at gmail.com>
wrote:
> Hi Gabriel,
> Are you using Windows? I think you cannot use g.list inside a command as
> we do in Linux. Solution would be to first get the list of comma separated
> map names and then paste it in the i.nightlights command.
> HTH,
> Vero
> El jue., 21 jun. 2018 11:05, Gabriel Cotlier <gabiklm01 at gmail.com>
> escribió:
>> I have tried to run i.i.nightlights.intercalibration on the command line
>> and got the following error:
>> What could be happening?
>> Thanks a lot
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180621/8f872f8e/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180621/8f872f8e/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180621/8f872f8e/attachment-0003.png>
