[GRASS-user] question on i.nightlights.intercalibration code
Veronica Andreo
veroandreo at gmail.com
Thu Jun 21 09:50:36 PDT 2018
It is a bit difficult to read, can you post the command you used? It seems
you typed image twice, suffic instead of suffix and you are using $() to
pass the list of map names which is not necesary, AFAIU. Try the following:
i.nightlights.intercalibration image=img1,img2,img3 suffix=c model=liu2012
if that does not work, then, Nikos will know ;)
best,
Vero
El jue., 21 jun. 2018 a las 18:34, Gabriel Cotlier (<gabiklm01 at gmail.com>)
escribió:
> Hello Vero,
> Thanks a lot for your response.
> I have tried that with no results, with the error in the image bellow:
> On Thu, Jun 21, 2018 at 12:12 PM, Veronica Andreo <veroandreo at gmail.com>
> wrote:
>> Hi Gabriel,
>> Are you using Windows? I think you cannot use g.list inside a command as
>> we do in Linux. Solution would be to first get the list of comma separated
>> map names and then paste it in the i.nightlights command.
>> HTH,
>> Vero
>> El jue., 21 jun. 2018 11:05, Gabriel Cotlier <gabiklm01 at gmail.com>
>> escribió:
>>> I have tried to run i.i.nightlights.intercalibration on the command line
>>> and got the following error:
>>> What could be happening?
>>> Thanks a lot
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180621/9afff5ef/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180621/9afff5ef/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180621/9afff5ef/attachment-0003.png>
