[GRASS-user] d.rast.edit - edits not saved
Frank David
frank.david at geophom.fr
Mon Jun 25 14:03:39 PDT 2018
Thank you Markus,
Sorry for my misunderstanding, I thought that you had improved this
script...
frk
Le 25/06/2018 à 22:20, Markus Neteler a écrit :
> Hello Frank,
> On Mon, Jun 25, 2018 at 6:56 PM, Frank David <frank.david at geophom.fr> wrote:
>> Hello Markus,
>> I failed to run the last d.rast.edit .I've saved on my disk the
>> html+py+makefile files and did g.extension extension=d.rast.edit
>> url=/myfolder/d.rast.edit but I can't execute from console. It says "Command
>> 'd.rast.edit' not yet implemented in the WxGUI. when trying to run from
>> shell the last version is launched ? The python file is well in
>> .grass7/addons/scripts/ ... I don't understand why it does not work. Thanks
>> for your help.
> Not sure what you want to achieve?
> I only edited the manual page.
> The only relevant message is that you need to hit "ENTER" after
> changing a value in the value field to activate it for following
> editing (should be improved, which I put as a new ticket).
> Your GRASS GIS installation already comes with the latest d.rast.edit
> code as long as you use 7.4.1.
> Best
> Markus
*Geophom*
327 rue de Vieille Cour 44521 OUDON
Tel +33(0)2 85 52 02 59 - Port +33(0)6 04 47 91 06
www.geophom.fr
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180625/2170351c/attachment.html>
