[GRASS-user] 7.5svn: create location from existing map
Rich Shepard
rshepard at appl-ecosys.com
Fri Jun 29 14:19:48 PDT 2018
The directory biota/ contains the subdirectory bulltrout/, which contains
two files and two subdirectories: VAR WIND dbf/ vector/. The map is named
bulltrout2008.
As this mapset became disconnected from the location in which it was
originally imported I want to learn how to turn it into a location or
otherwise access it to reproject the bulltrout2008 map to a different
projection.
If there's a module for this I've missed seeing it.
TIA,
Rich
