[GRASS-user] r.in.lidar build errors [UPDATE]
Rich Shepard rshepard at appl-ecosys.com
Wed Mar 7 09:01:30 PST 2018
On Tue, 6 Mar 2018, Rich Shepard wrote:
> (r.in.lidar) : /error while loading shared libraries: libproj.so.12:
> cannot open shared object file: No such file or directory
> ../../include/Make/Html.make:14: recipe for target 'r.in.lidar.tmp.html'
> failed
> make: *** [r.in.lidar.tmp.html] Error 1
> rm r.in.lidar.tmp.html
   I see that someone added a couple of .html files to the trunck branch in
release 72331. Unfortunately, these did not fis the problems. Here're the
error messages and the results of running 'make' in each directory:
Errors in:
/home/rshepard/gis/grass/grass7_trunk/raster/r.in.lidar
/home/rshepard/gis/grass/grass7_trunk/raster3d/r3.in.lidar
/home/rshepard/gis/grass/grass7_trunk/vector/v.out.lidar
/home/rshepard/gis/grass/grass7_trunk/vector/v.in.lidar
~/gis/grass/grass7_trunk/raster/r.in.lidar]$ make
if [ "/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/r.in.lidar" != "" ] ; then GISRC=/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/demolocation/.grassrc75 GISBASE=/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu PATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/scripts:$PATH" PYTHONPATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/etc/python:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/gui/wxpython:$PYTHONPATH" LD_LIBRARY_PATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/scripts:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/lib:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/lib:/usr/lib/qt
 /lib:" LC_ALL=C LANG=C LANGUAGE=C /home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/r.in.lidar --html-description < /dev/null | grep -v '</body>\|</html>' > r.in.lidar.tmp.html ; fi
/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/r.in.lidar: error while loading shared libraries: libproj.so.12: cannot open shared object file: No such file or directory
../../include/Make/Html.make:14: recipe for target 'r.in.lidar.tmp.html' failed
~/gis/grass/grass7_trunk/raster3d/r3.in.lidar]$ make
if [ "/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/r3.in.lidar" != "" ] ; then GISRC=/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/demolocation/.grassrc75 GISBASE=/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu PATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/scripts:$PATH" PYTHONPATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/etc/python:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/gui/wxpython:$PYTHONPATH" LD_LIBRARY_PATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/scripts:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/lib:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/lib:/usr/lib/q
 t/lib:" LC_ALL=C LANG=C LANGUAGE=C /home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/r3.in.lidar --html-description < /dev/null | grep -v '</body>\|</html>' > r3.in.lidar.tmp.html ; fi
/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/r3.in.lidar: error while loading shared libraries: libproj.so.12: cannot open shared object file: No such file or directory
../../include/Make/Html.make:14: recipe for target 'r3.in.lidar.tmp.html' failed
make: *** [r3.in.lidar.tmp.html] Error 1
rm r3.in.lidar.tmp.html
~/gis/grass/grass7_trunk/vector/v.out.lidar]$ make
if [ "/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/v.out.lidar" != "" ] ; then GISRC=/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/demolocation/.grassrc75 GISBASE=/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu PATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/scripts:$PATH" PYTHONPATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/etc/python:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/gui/wxpython:$PYTHONPATH" LD_LIBRARY_PATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/scripts:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/lib:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/lib:/usr/lib/q
 t/lib:" LC_ALL=C LANG=C LANGUAGE=C /home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/v.out.lidar --html-description < /dev/null | grep -v '</body>\|</html>' > v.out.lidar.tmp.html ; fi
/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/v.out.lidar: error while loading shared libraries: libproj.so.12: cannot open shared object file: No such file or directory
../../include/Make/Html.make:14: recipe for target 'v.out.lidar.tmp.html' failed
make: *** [v.out.lidar.tmp.html] Error 1
rm v.out.lidar.tmp.html
~/gis/grass/grass7_trunk/vector/v.in.lidar]$ make
if [ "/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/v.in.lidar" != "" ] ; then GISRC=/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/demolocation/.grassrc75 GISBASE=/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu PATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/scripts:$PATH" PYTHONPATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/etc/python:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/gui/wxpython:$PYTHONPATH" LD_LIBRARY_PATH="/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/scripts:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/lib:/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/lib:/usr/lib/qt
 /lib:" LC_ALL=C LANG=C LANGUAGE=C /home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/v.in.lidar --html-description < /dev/null | grep -v '</body>\|</html>' > v.in.lidar.tmp.html ; fi
/home/rshepard/gis/grass/grass7_trunk/dist.i686-pc-linux-gnu/bin/v.in.lidar: error while loading shared libraries: libproj.so.12: cannot open shared object file: No such file or directory
../../include/Make/Html.make:14: recipe for target 'v.in.lidar.tmp.html' failed
make: *** [v.in.lidar.tmp.html] Error 1
rm v.in.lidar.tmp.html
   Perhaps later today or tomorrow?
TIA,
Rich
