[GRASS-user] r.in.lidar build errors
Markus Metz
markus.metz.giswork at gmail.com
Wed Mar 7 13:52:00 PST 2018
On Wed, Mar 7, 2018 at 10:27 PM, Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> On Wed, 7 Mar 2018, Markus Metz wrote:
>> Apparently your liblas installation does not find libproj.so.12.
> Markus,
> There are two issues and I think they're becoming conflated.
> Issue 1: I cannot invoke the installed grass-7.5 because it was built
> against libproj.so.12.0.0 and that library has been upgraded to
> libproj.so.13.0.0.
that means you need to rebuild liblas and maybe its dependencies, before
you recompile GRASS
Markus M
> This issue will be resolved by building the new svn
> source against the newer libproj library.
> Issue 2: Building the new version fails because of errors in:
> /home/rshepard/gis/grass/grass7_trunk/raster/r.in.lidar
> /home/rshepard/gis/grass/grass7_trunk/raster3d/r3.in.lidar
> /home/rshepard/gis/grass/grass7_trunk/vector/v.out.lidar
> /home/rshepard/gis/grass/grass7_trunk/vector/v.in.lidar
> and when I run make in each of those directories it fails because it
cannot
> find the *.tmp.html files.
> I can re-post those attempts at running 'make' in each *.lidar directory
> if desired.
> HTH,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180307/8bcebf46/attachment.html>
