[GRASS-user] LiDAR in Grass GIS
Martin Landa landa.martin at gmail.com
Wed Mar 21 04:55:37 PDT 2018
[please keep discussion on ML]
2018-03-21 11:39 GMT+01:00 Shane Carey <careyshan at gmail.com>:
> ERROR: Projection of dataset does not appear to match current location.
> Dataset proj = 0 (unreferenced/unknown)
> However, I have set the projection of the dataset, so I know its not that.
by "dataset" do you mean location or input data (LAZ/LAS)? Anyway
error says, that input data (LAS/LAZ) lacks SRS info. If you are sure
that your GRASS location has been set up correctly (check by `g.proj
-p`) that you can use `-o` to skip projection check, see r.in.lidar
manual page for details.
Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
