[GRASS-user] LiDAR in Grass GIS
Shane Carey
careyshan at gmail.com
Wed Mar 21 11:45:34 PDT 2018
Ok great - I will try that! Thanks
On Céad 21 Márta 2018 at 11:55, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> [please keep discussion on ML]
> 2018-03-21 11:39 GMT+01:00 Shane Carey <careyshan at gmail.com>:
> > ERROR: Projection of dataset does not appear to match current location.
> > Dataset proj = 0 (unreferenced/unknown)
> > However, I have set the projection of the dataset, so I know its not
> that.
> by "dataset" do you mean location or input data (LAZ/LAS)? Anyway
> error says, that input data (LAS/LAZ) lacks SRS info. If you are sure
> that your GRASS location has been set up correctly (check by `g.proj
> -p`) that you can use `-o` to skip projection check, see r.in.lidar
> manual page for details.
> Ma
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
Le gach dea ghui,
*Shane Carey*
*GIS and Data Solutions Consultant*
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180321/b2f742df/attachment.html>
