[GRASS-user] GUI problem
Frank David frank.david at geophom.fr
Sat Mar 31 08:43:28 PDT 2018
Hi Mortiz,
Le 30/03/2018 à 15:07, Moritz Lennert a écrit :
> Hi Frank,
> On 30/03/18 11:23, Frank David wrote:
>> Hi all,
>> I've met a problem this morning on only one of my project. The map are
>> displayed but I cannot do anything on GUI, no command message returned
>> but the message below on GUI console >
>> Traceback (most recent call last):
>>    File
>> "/usr/local/grass-7.4.0svn/gui/wxpython/gui_core/forms.py",
>> line 836, in OnRun
>> ret = self._gconsole.RunCmd(cmd, onDone=self.OnDone)
>>    File
>> "/usr/local/grass-7.4.0svn/gui/wxpython/core/gconsole.py",
>> line 467, in RunCmd
>> self.UpdateHistoryFile(' '.join(command))
>>    File
>> line 748, in UpdateHistoryFile
>> {'filePath': filePath, 'error': e},
>> UnicodeDecodeError
>> 'ascii' codec can't decode byte 0xc3 in position 32: ordinal
>> not in range(128)
> This means that there is some issue with non-ASCII characters (in
> French it's often accents), either in a path or in an error message.
> This is a bug and it would be great if you could report it on the bug
> tacker [1].
> But in the meantime, in case the error comes from special characters
> in a French error message, you could switch the GUI to English and
> then relaunch it to see what the error message is. If the error is
> linked to special characters in a path, try to move everything into a
> pure ASCII path .
> Moritz
> [1] https://trac.osgeo.org/grass/
Thanks for your reply.
I don't understand from where the accent could come,  because I do not
remember to have change anything on my project. I did not change path
name neither. Can you advice me where to find the problem ?
Thanks !
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180331/f7576183/attachment.html>
