[GRASS-user] FW: Stream order from existing stream network layer
Stefan Blumentrath Stefan.Blumentrath at nina.no
Tue May 1 00:00:47 PDT 2018
Forgot the list…
Sent: tirsdag 1. mai 2018 08.57
To: 'Shane Carey' <careyshan at gmail.com>
Subject: RE: [GRASS-user] Stream order from existing stream network layer
Hi Shane,
Please have a look at:
https://grass.osgeo.org/grass74/manuals/addons/v.stream.order.html
Then you can use v.rast.stats to collect some statistics…
Cheers
Stefan
From: grass-user <grass-user-bounces at lists.osgeo.org<mailto:grass-user-bounces at lists.osgeo.org>> On Behalf Of Shane Carey
Sent: tirsdag 1. mai 2018 00.37
To: grass-user grass-user <grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>>
Subject: [GRASS-user] Stream order from existing stream network layer
Is there way of calculating the stream order from an existing vector dataset in Grass GIS? The vector layer has been created from manual digitising.
In addition, is it possible to obtain other stream characteristics for this layer that you would obtain from "r.stream.segment"
Thanks in advance
Le gach dea ghui,
Shane Carey
GIS and Data Solutions Consultant
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180501/2a897403/attachment.html>
