[GRASS-user] Stream order from existing stream network layer
Shane Carey careyshan at gmail.com
Tue May 1 04:35:11 PDT 2018
Super - thank you! I will give this a go first and get back to you if I get
stuck. Thanks again.
Cheers
Le gach dea ghui,
*Shane Carey*
*GIS and Data Solutions Consultant*
On Tue, May 1, 2018 at 12:01 PM, Stefan Blumentrath <
Stefan.Blumentrath at nina.no> wrote:
> Hi Shane,
> If your network dataset is directed, you could use:
> https://github.com/NINAnor/gudbrand_hydro/blob/master/v.igraph.order.py
> to classify the nodes from which you then can generate the outlet vector
> point map for v.stream.order.
> If your network is not directed, you could use v.to.points or v.net to
> dump the points, add altitude information from a terrain model
> (v.what.rast), and then extract the lowest points as outlets (requires some
> SQL).
> For more support we would need a bit more information about your data…
> Cheers
> Stefan
> *From:* Shane Carey <careyshan at gmail.com>
> *Sent:* tirsdag 1. mai 2018 10.29
> *To:* Stefan Blumentrath <Stefan.Blumentrath at nina.no>
> *Subject:* Re: [GRASS-user] Stream order from existing stream network
> layer
> Hi Stefan,
> I had a look at this, but it requires a point layer also - which I don't
> have unfortunately.
> Thanks
> Le gach dea ghui,
> *Shane Carey*
> On Tue, May 1, 2018 at 7:57 AM, Stefan Blumentrath <
> Hi Shane,
> Please have a look at:
> https://grass.osgeo.org/grass74/manuals/addons/v.stream.order.html
> Then you can use v.rast.stats to collect some statistics…
> Cheers
> Stefan
> *From:* grass-user <grass-user-bounces at lists.osgeo.org> *On Behalf Of *Shane
> Carey
> *Sent:* tirsdag 1. mai 2018 00.37
> *To:* grass-user grass-user <grass-user at lists.osgeo.org>
> *Subject:* [GRASS-user] Stream order from existing stream network layer
> Hi,
> Is there way of calculating the stream order from an existing vector
> dataset in Grass GIS? The vector layer has been created from manual
> digitising.
> In addition, is it possible to obtain other stream characteristics for
> this layer that you would obtain from *"r.stream.segment"*
> Thanks in advance
> Le gach dea ghui,
> *Shane Carey*
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180501/ec239b84/attachment.html>
