[GRASS-user] To import from or to link to data stored in a PostgreSQL data base?
Nikos Alexandris
nik at nikosalexandris.net
Thu May 10 05:58:59 PDT 2018
That's an interesting idea. Monday, when the JRC is open again, will be
the day to test that.
Thank you Stefan. Thank you also Markus for the tips.
I am positive that eventually we will find a balanced approach for the
workflow.
Cheers, Nikos
* Stefan Blumentrath <Stefan.Blumentrath at nina.no> [2018-05-08 18:31:49 +0000]:
>Hei Nikos,
>What about using gdal_rasterize and then r.external output=MASK?
>Cheers
>Stefan
>________________________________
>From: grass-user <grass-user-bounces at lists.osgeo.org> on behalf of Nikos Alexandris <nik at nikosalexandris.net>
>Sent: Tuesday, May 8, 2018 4:01:14 PM
>To: GRASS-GIS user mailing list
>Cc: Giacomo.DELLI at ext.ec.europa.eu
>Subject: [GRASS-user] To import from or to link to data stored in a PostgreSQL data base?
>Dears,
>the following concerns an update of an existing workflow, part of which
>is GRASS GIS, that makes use of a large PostgreSQL data base which does
>not reside locally.
>The original data set consists of tens of thousands of (overlapping)
>polygons. The data are required solely to build raster MASKs.
>So, importing the whole of it, is an overkill. Instead, options, already
>working, are to split all records in single tables or views. Then access
>these via GRASS to perform some analytics.
>First instructions of the workflow are:
>- read a (external) vector map
>- set the computational region
>- build a raster mask.
>Building a MASK using a pseudo vector map that links to an
>external table, stored in a PostgreSQL data base, is times slower than
>importing the vetor of interest in GRASS GIS and then building a MASK
>using the "native" GRASS GIS vector map.
>Giacomo timed different options, using `v.external` as well as importing
>the data using `v.in.ogr`. Specifically,
>- building a MASK using one pseudo vector map (without and with a
> spatial-index), takes about 9 minutes (real time).
>time r.mask vector=test_nogeoindex --o
>real 8m40.306s
>user 5m14.225s
>sys 0m56.378s
>and
>time r.mask vector=test_geoindex --o
>real 8m46.096s
>user 5m15.693s
>sys 0m56.346s
>- building a MASK using a native GRASS GIS vector map, imported via a
> table or a view, takes about 0.4 seconds.
>real 0m0.373s
>user 0m0.191s
>sys 0m0.111s
>and
>real 0m0.350s
>user 0m0.179s
>sys 0m0.115s
>For the latter, building a view is way faster than a table (half a
>minute for more than 20000 views, while it would take approximately an
>hour to build single tables).
>The trade-off appears to be space vs time. If data are imported, more
>disk space is required. If data are not imported, and `v.external` is
>used, then `r.mask` takes too much time to build a raster MASK.
>- Is it acceptable for `r.mask` to take so long in building a MASK based
> on an external vector map stored in a PostgreSQL data base?
>- Is network connection a limiting factor here, since the PG data base
> is not local?
>- Would anyone have any recommendations/considerations on this approach?
>Thank you, Nikos
Nikos Alexandris | Remote Sensing & Geomatics
GPG Key Fingerprint 6F9D4506F3CA28380974D31A9053534B693C4FB3
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180510/4374ba8b/attachment.sig>
