[GRASS-user] To import from or to link to data stored in a PostgreSQL data base?
Nikos Alexandris
nik at nikosalexandris.net
Tue May 15 08:13:09 PDT 2018
Update: Stefan's suggestion is worth. First test show that we can save a
lot of time.
Thank you so much Stefan and community.
Nikos
* Nikos Alexandris <nik at nikosalexandris.net> [2018-05-10 14:58:59 +0200]:
>That's an interesting idea. Monday, when the JRC is open again, will be
>the day to test that.
>Thank you Stefan. Thank you also Markus for the tips.
>I am positive that eventually we will find a balanced approach for the
>workflow.
>Cheers, Nikos
>* Stefan Blumentrath <Stefan.Blumentrath at nina.no> [2018-05-08 18:31:49 +0000]:
>>Hei Nikos,
>>What about using gdal_rasterize and then r.external output=MASK?
>>Cheers
>>Stefan
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180515/2911fc8a/attachment.sig>
