[GRASS-user] v vol rst super slow
Francois Chartier
fra.chartier at gmail.com
Wed May 23 04:09:21 PDT 2018
see below
*g.region -3p*
projection: 1 (UTM)
zone: 17
datum: nad83
ellipsoid: grs80
north: 4870795
south: 4825715
west: 609204
east: 651669
top: 352.00000000
bottom: 45.00000000
nsres: 5
nsres3: 5
ewres: 5
ewres3: 5
tbres: 1
rows: 9016
rows3: 9016
cols: 8493
cols3: 8493
depths: 307
cells: 76572888
cells3: 23507876616
for v.vol.rst command line - i am not sure where you get this so i just
restarted the simulation.
Wed May 23 07:07:59 2018)
v.vol.rst input=BHMat1All_May12 at Toronto wcolumn=cat dmin=0.1
25 records selected from table
Processing all selected output files will require 0 bytes of disk space for
temp files
WARNING: Points are more dense than specified 'DMIN'--ignored 65 points
(remain 76822)
WARNING: Unable to create <(null)> raster map without cross_input raster
map being specified
*v.info <http://v.info>*
*(Wed May 23 07:06:24 2018)
v.info <http://v.info> map=BHMat1All_May12 at Toronto
| | Mapset: Toronto
| | Database: C:\Users\Francois
Chartier\Documents\grassdata | | Title:
| | Map scale: 1:1
| | Name of creator:
Francois Chartier | |
Organization:
| | Source date: Sat May 12 15:45:44 2018
| | Timestamp (first layer): none
Map format: native
Type of map: vector (level: 2)
| | Number of points: 76887 Number of centroids: 0
| | Number of lines: 0 Number of boundaries:
0 | | Number of areas: 0 Number of
islands: 0 | | Number of faces: 0 Number
of kernels: 0 | | Number of volumes: 0
Number of holes: 0 | |
| | Map is 3D: Yes
| | Number of dblinks: 1
| | Projection: UTM
(zone 17) | |
N: 4870795 S: 4825715 | |
E: 651669 W: 609204 | |
B: 45 T: 352
| | Digitization threshold: 0
| | Comment:
| +----------------------------------------------------------------------------+(Wed
May 23 07:06:24 2018) Command finished (0 sec) *
2018-05-23 6:07 GMT-04:00 Moritz Lennert <mlennert at club.worldonline.be>:
> Hi François,
> Please keep all discussions on the list.
> On 23/05/18 02:26, Francois Chartier wrote:
>> Hi Moritz,
>> see below. seems like i have 6M cells
>> projection: 1 (UTM)
>> zone: 17
>> datum: nad83
>> ellipsoid: grs80
>> north: 4868980
>> south: 4829680
>> west: 609620
>> east: 651628
>> nsres: 5
>> ewres: 4.99976196
>> rows: 7860
>> cols: 8402
>> cells: 66039720
> Sorry, my fault: as you are interpolating in 3D we need the 3D region, so
> the output of 'g.region -3p'.
> And could you also provide us with:
> - the exact v.vol.rst command line you used
> - the output of v.info on your point dataset
> Moritz
>> 2018-05-22 7:58 GMT-04:00 Moritz Lennert <mlennert at club.worldonline.be
>> <mailto:mlennert at club.worldonline.be>>:
>> Am 22. Mai 2018 04:35:13 MESZ schrieb Francois Chartier
>> <fra.chartier at gmail.com <mailto:fra.chartier at gmail.com>>:
>> >Hi,
>> >I am interpolating 2D data using V Vol RST. After 90 min the
>> process
>> >progressed 15%, and I stopped it.
>> >There are approx 370 points, and it should not take this long. I am
>> >not
>> >sure what I am doing incorrectly. I have set the g.region to
>> match the
>> >vector, and joined the vector attribute to the database.
>> What is the resolution of the region ?
>> Please provide the output of g.region -p.
>> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180523/0dec4e3d/attachment.html>
