[GRASS-user] v vol rst super slow
Markus Metz
markus.metz.giswork at gmail.com
Wed May 23 12:30:06 PDT 2018
On Wed, May 23, 2018 at 1:09 PM, Francois Chartier <fra.chartier at gmail.com>
wrote:
> see below
> g.region -3p
> projection: 1 (UTM)
> zone: 17
> datum: nad83
> ellipsoid: grs80
> north: 4870795
> south: 4825715
> west: 609204
> east: 651669
> top: 352.00000000
> bottom: 45.00000000
> nsres: 5
> nsres3: 5
> ewres: 5
> ewres3: 5
> tbres: 1
> rows: 9016
> rows3: 9016
> cols: 8493
> cols3: 8493
> depths: 307
> cells: 76572888
> cells3: 23507876616
> for v.vol.rst command line - i am not sure where you get this so i just
restarted the simulation.
> Wed May 23 07:07:59 2018)
> v.vol.rst input=BHMat1All_May12 at Toronto wcolumn=cat dmin=0.1
> 25 records selected from table
> Processing all selected output files will require 0 bytes of disk space
for temp files
> WARNING: Points are more dense than specified 'DMIN'--ignored 65 points
(remain 76822)
> WARNING: Unable to create <(null)> raster map without cross_input raster
map being specified
> v.info
> (Wed May 23 07:06:24 2018)
> v.info map=BHMat1All_May12 at Toronto
> | Mapset: Toronto
> | Location: Toronto
> | Database: C:\Users\Francois Chartier\Documents\grassdata
> | Title:
> | Map scale: 1:1
> | Name of creator: Francois Chartier
> | Organization:
> | Source date: Sat May 12 15:45:44 2018
> | Timestamp (first layer): none
> | Map format: native
> | Type of map: vector (level: 2)
> | Number of points: 76887 Number of centroids: 0
> | Number of lines: 0 Number of boundaries: 0
> | Number of areas: 0 Number of islands: 0
> | Number of faces: 0 Number of kernels: 0
> | Number of volumes: 0 Number of holes: 0
> | Map is 3D: Yes
> | Number of dblinks: 1
> | Projection: UTM (zone 17)
> | N: 4870795 S: 4825715
> | E: 651669 W: 609204
> | B: 45 T: 352
> | Digitization threshold: 0
> | Comment:
> (Wed May 23 07:06:24 2018) Command finished (0 sec)
The current target resolutions of
nsres3: 5
ewres3: 5
tbres: 1
are much too high for the given extents and the coverage of the input points
According to the output of v.info, a point covers on average about 7643645
cubic meters which corresponds to voxels with edge length of about 200
meters. Therefore a good starting point would be a 3D region with
resolutions in all 3 dimensions of 200 meter. If the results make sense,
the resolutions can be slowly increased.
Markus M
> 2018-05-23 6:07 GMT-04:00 Moritz Lennert <mlennert at club.worldonline.be>:
>> Hi François,
>> Please keep all discussions on the list.
>> On 23/05/18 02:26, Francois Chartier wrote:
>>> Hi Moritz,
>>> see below. seems like i have 6M cells
>>> projection: 1 (UTM)
>>> zone: 17
>>> datum: nad83
>>> ellipsoid: grs80
>>> north: 4868980
>>> south: 4829680
>>> west: 609620
>>> east: 651628
>>> nsres: 5
>>> ewres: 4.99976196
>>> rows: 7860
>>> cols: 8402
>>> cells: 66039720
>> Sorry, my fault: as you are interpolating in 3D we need the 3D region,
so the output of 'g.region -3p'.
>> And could you also provide us with:
>> - the exact v.vol.rst command line you used
>> - the output of v.info on your point dataset
>> Moritz
>>> 2018-05-22 7:58 GMT-04:00 Moritz Lennert <mlennert at club.worldonline.be
<mailto:mlennert at club.worldonline.be>>:
>>> Am 22. Mai 2018 04:35:13 MESZ schrieb Francois Chartier
>>> <fra.chartier at gmail.com <mailto:fra.chartier at gmail.com>>:
>>> >Hi,
>>> >I am interpolating 2D data using V Vol RST. After 90 min the
process
>>> >progressed 15%, and I stopped it.
>>> >There are approx 370 points, and it should not take this long. I
am
>>> >not
>>> >sure what I am doing incorrectly. I have set the g.region to
>>> match the
>>> >vector, and joined the vector attribute to the database.
>>> What is the resolution of the region ?
>>> Please provide the output of g.region -p.
>>> Moritz
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180523/70d20e17/attachment.html>
