[GRASS-user] v vol rst super slow
Francois Chartier
fra.chartier at gmail.com
Wed May 23 18:02:58 PDT 2018
How do you change the resolution to something coarser?
2018-05-23 15:30 GMT-04:00 Markus Metz <markus.metz.giswork at gmail.com>:
> On Wed, May 23, 2018 at 1:09 PM, Francois Chartier <fra.chartier at gmail.com>
> wrote:
> > see below
> > g.region -3p
> > projection: 1 (UTM)
> > zone: 17
> > datum: nad83
> > ellipsoid: grs80
> > north: 4870795
> > south: 4825715
> > west: 609204
> > east: 651669
> > top: 352.00000000
> > bottom: 45.00000000
> > nsres: 5
> > nsres3: 5
> > ewres: 5
> > ewres3: 5
> > tbres: 1
> > rows: 9016
> > rows3: 9016
> > cols: 8493
> > cols3: 8493
> > depths: 307
> > cells: 76572888
> > cells3: 23507876616
> > for v.vol.rst command line - i am not sure where you get this so i just
> restarted the simulation.
> > Wed May 23 07:07:59 2018)
> > v.vol.rst input=BHMat1All_May12 at Toronto wcolumn=cat dmin=0.1
> > 25 records selected from table
> > Processing all selected output files will require 0 bytes of disk space
> for temp files
> > WARNING: Points are more dense than specified 'DMIN'--ignored 65 points
> (remain 76822)
> > WARNING: Unable to create <(null)> raster map without cross_input raster
> map being specified
> > v.info
> > (Wed May 23 07:06:24 2018)
> > v.info map=BHMat1All_May12 at Toronto
> > | Mapset: Toronto
> > | Location: Toronto
> > | Database: C:\Users\Francois Chartier\Documents\grassdata
> > | Title:
> > | Map scale: 1:1
> > | Name of creator: Francois Chartier
> > | Organization:
> > | Source date: Sat May 12 15:45:44 2018
> > | Timestamp (first layer): none
> > | Map format: native
> > | Type of map: vector (level: 2)
> > | Number of points: 76887 Number of centroids: 0
> > | Number of lines: 0 Number of boundaries: 0
> > | Number of areas: 0 Number of islands: 0
> > | Number of faces: 0 Number of kernels: 0
> > | Number of volumes: 0 Number of holes: 0
> > | Map is 3D: Yes
> > | Number of dblinks: 1
> > | Projection: UTM (zone 17)
> > | N: 4870795 S: 4825715
> > | E: 651669 W: 609204
> > | B: 45 T: 352
> > | Digitization threshold: 0
> > | Comment:
> > (Wed May 23 07:06:24 2018) Command finished (0 sec)
> The current target resolutions of
> nsres3: 5
> ewres3: 5
> tbres: 1
> are much too high for the given extents and the coverage of the input
> points
> According to the output of v.info, a point covers on average about
> 7643645 cubic meters which corresponds to voxels with edge length of about
> 200 meters. Therefore a good starting point would be a 3D region with
> resolutions in all 3 dimensions of 200 meter. If the results make sense,
> the resolutions can be slowly increased.
> Markus M
> > 2018-05-23 6:07 GMT-04:00 Moritz Lennert <mlennert at club.worldonline.be>:
> >> Hi François,
> >> Please keep all discussions on the list.
> >> On 23/05/18 02:26, Francois Chartier wrote:
> >>> Hi Moritz,
> >>> see below. seems like i have 6M cells
> >>> projection: 1 (UTM)
> >>> zone: 17
> >>> datum: nad83
> >>> ellipsoid: grs80
> >>> north: 4868980
> >>> south: 4829680
> >>> west: 609620
> >>> east: 651628
> >>> nsres: 5
> >>> ewres: 4.99976196
> >>> rows: 7860
> >>> cols: 8402
> >>> cells: 66039720
> >> Sorry, my fault: as you are interpolating in 3D we need the 3D region,
> so the output of 'g.region -3p'.
> >> And could you also provide us with:
> >> - the exact v.vol.rst command line you used
> >> - the output of v.info on your point dataset
> >> Moritz
> >>> 2018-05-22 7:58 GMT-04:00 Moritz Lennert <mlennert at club.worldonline.be
> <mailto:mlennert at club.worldonline.be>>:
> >>> Am 22. Mai 2018 04:35:13 MESZ schrieb Francois Chartier
> >>> <fra.chartier at gmail.com <mailto:fra.chartier at gmail.com>>:
> >>> >Hi,
> >>> >I am interpolating 2D data using V Vol RST. After 90 min the
> process
> >>> >progressed 15%, and I stopped it.
> >>> >There are approx 370 points, and it should not take this long.
> I am
> >>> >not
> >>> >sure what I am doing incorrectly. I have set the g.region to
> >>> match the
> >>> >vector, and joined the vector attribute to the database.
> >>> What is the resolution of the region ?
> >>> Please provide the output of g.region -p.
> >>> Moritz
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180523/850132f9/attachment-0001.html>
