[GRASS-user] v vol rst super slow
Anna Petrášová
kratochanna at gmail.com
Wed May 23 18:42:28 PDT 2018
On Wed, May 23, 2018 at 9:02 PM, Francois Chartier
<fra.chartier at gmail.com> wrote:
> How do you change the resolution to something coarser?
With g.region, res= is horizontal and tbres= is vertical resolution, e.g:
g.region res=200 tbres=200 -p3
> 2018-05-23 15:30 GMT-04:00 Markus Metz <markus.metz.giswork at gmail.com>:
>> On Wed, May 23, 2018 at 1:09 PM, Francois Chartier
>> > see below
>> > g.region -3p
>> > projection: 1 (UTM)
>> > zone: 17
>> > datum: nad83
>> > ellipsoid: grs80
>> > north: 4870795
>> > south: 4825715
>> > west: 609204
>> > east: 651669
>> > top: 352.00000000
>> > bottom: 45.00000000
>> > nsres: 5
>> > nsres3: 5
>> > ewres: 5
>> > ewres3: 5
>> > tbres: 1
>> > rows: 9016
>> > rows3: 9016
>> > cols: 8493
>> > cols3: 8493
>> > depths: 307
>> > cells: 76572888
>> > cells3: 23507876616
>> > for v.vol.rst command line - i am not sure where you get this so i just
>> > restarted the simulation.
>> > Wed May 23 07:07:59 2018)
>> > v.vol.rst input=BHMat1All_May12 at Toronto wcolumn=cat dmin=0.1
>> > 25 records selected from table
>> > Processing all selected output files will require 0 bytes of disk space
>> > for temp files
>> > WARNING: Points are more dense than specified 'DMIN'--ignored 65 points
>> > (remain 76822)
>> > WARNING: Unable to create <(null)> raster map without cross_input raster
>> > map being specified
>> > v.info
>> > (Wed May 23 07:06:24 2018)
>> > v.info map=BHMat1All_May12 at Toronto
>> > | Mapset: Toronto
>> > | Location: Toronto
>> > | Database: C:\Users\Francois Chartier\Documents\grassdata
>> > | Title:
>> > | Map scale: 1:1
>> > | Name of creator: Francois Chartier
>> > | Organization:
>> > | Source date: Sat May 12 15:45:44 2018
>> > | Timestamp (first layer): none
>> > | Map format: native
>> > | Type of map: vector (level: 2)
>> > | Number of points: 76887 Number of centroids: 0
>> > | Number of lines: 0 Number of boundaries: 0
>> > | Number of areas: 0 Number of islands: 0
>> > | Number of faces: 0 Number of kernels: 0
>> > | Number of volumes: 0 Number of holes: 0
>> > | Map is 3D: Yes
>> > | Number of dblinks: 1
>> > | Projection: UTM (zone 17)
>> > | N: 4870795 S: 4825715
>> > | E: 651669 W: 609204
>> > | B: 45 T: 352
>> > | Digitization threshold: 0
>> > | Comment:
>> > (Wed May 23 07:06:24 2018) Command finished (0 sec)
>> The current target resolutions of
>> nsres3: 5
>> ewres3: 5
>> tbres: 1
>> are much too high for the given extents and the coverage of the input
>> points
>> According to the output of v.info, a point covers on average about 7643645
>> cubic meters which corresponds to voxels with edge length of about 200
>> meters. Therefore a good starting point would be a 3D region with
>> resolutions in all 3 dimensions of 200 meter. If the results make sense, the
>> resolutions can be slowly increased.
>> Markus M
>> > 2018-05-23 6:07 GMT-04:00 Moritz Lennert <mlennert at club.worldonline.be>:
>> >> Hi François,
>> >> Please keep all discussions on the list.
>> >> On 23/05/18 02:26, Francois Chartier wrote:
>> >>> Hi Moritz,
>> >>> see below. seems like i have 6M cells
>> >>> projection: 1 (UTM)
>> >>> zone: 17
>> >>> datum: nad83
>> >>> ellipsoid: grs80
>> >>> north: 4868980
>> >>> south: 4829680
>> >>> west: 609620
>> >>> east: 651628
>> >>> nsres: 5
>> >>> ewres: 4.99976196
>> >>> rows: 7860
>> >>> cols: 8402
>> >>> cells: 66039720
>> >> Sorry, my fault: as you are interpolating in 3D we need the 3D region,
>> >> so the output of 'g.region -3p'.
>> >> And could you also provide us with:
>> >> - the exact v.vol.rst command line you used
>> >> - the output of v.info on your point dataset
>> >> Moritz
>> >>> 2018-05-22 7:58 GMT-04:00 Moritz Lennert <mlennert at club.worldonline.be
>> >>> <mailto:mlennert at club.worldonline.be>>:
>> >>> Am 22. Mai 2018 04:35:13 MESZ schrieb Francois Chartier
>> >>> <fra.chartier at gmail.com <mailto:fra.chartier at gmail.com>>:
>> >>> >Hi,
>> >>> >I am interpolating 2D data using V Vol RST. After 90 min the
>> >>> process
>> >>> >progressed 15%, and I stopped it.
>> >>> >There are approx 370 points, and it should not take this long.
>> >>> I am
>> >>> >not
>> >>> >sure what I am doing incorrectly. I have set the g.region to
>> >>> match the
>> >>> >vector, and joined the vector attribute to the database.
>> >>> What is the resolution of the region ?
>> >>> Please provide the output of g.region -p.
>> >>> Moritz
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/grass-user
