[GRASS-user] reorder columns in vector attribute table
Veronica Andreo veroandreo at gmail.com
Wed May 23 13:44:05 PDT 2018
Thanks all of you for your answers :)
I created the ticket as a defect [0], but please feel free to change it to
enhancement if you consider so.
In the meantime, this is what I do for all columns in the attr table of my
vector maps to get column order, type and width right (plus change name
from uppercase to lowercase):
# 1. add new column (low caps, define width if possible; date does not
allow width definition)
v.db.addcolumn $MAP column="start_date_new date"
# 2. update values from corresponding original column
v.db.update $MAP column=start_date_new query_column=START_DATE
# 3. remove original column
v.db.dropcolumn $MAP column=START_DATE
# 4. rename newly created column
v.db.renamecolumn $MAP column=start_date_new,start_date
# 5. check
v.db.select $MAP | head
cheers,
Vero
[0] https://trac.osgeo.org/grass/ticket/3566
El mié., 23 may. 2018 a las 21:58, Markus Metz (<
markus.metz.giswork at gmail.com>) escribió:
> On Wed, May 23, 2018 at 12:41 PM, Moritz Lennert <
> mlennert at club.worldonline.be> wrote:
> > Am 23. Mai 2018 12:23:45 MESZ schrieb Stefan Blumentrath <
> Stefan.Blumentrath at nina.no>:
> > >Ciao Vero,
> > >Unfortunately, it seems you have to create a new table with desired
> > >column order, copy data into it (INSERT INTO FROM SELECT) and then link
> > >the new table to your vector map (v.db.connect)…:
> https://stackoverflow.com/questions/20574113/sqlite3-how-to-reorder-columns-in-a-table
> > Personally I would consider this as a bug. v.patch should match columns
> by names
> and type
> > not order. But I haven't looked at the code yet to understand what this
> would entail.
> in theory this (ignore order, check name+type match) is easy to implement.
> Please open a ticket.
> Markus M
> > Moritz
> > >Note that SQLite will launder column names to lower case if you don`t
> > >quote them. Then they may not match even if in proper order
> > >(speculating here)…
> > >Cheers
> > >Stefan
> > >From: grass-user <grass-user-bounces at lists.osgeo.org> On Behalf Of
> > >Veronica Andreo
> > >Sent: onsdag 23. mai 2018 12.12
> > >To: grass-user <grass-user at lists.osgeo.org>
> > >Subject: [GRASS-user] reorder columns in vector attribute table
> > >Hi all,
> > >I want to use v.patch -e to patch geometries and attributes of polygon
> > >maps belonging to different states in Australia and the column names in
> > >the attr tables are the same (they only vary in the order in which they
> > >are) but when making an attempt, I get:
> > >v.patch -e input=act_bushfire_2012_2017,tas_bushfire_2012_2017
> > >output=test
> > >ERROR: Column names differ
> > >Column names here:
> > >v.db.select tas_bushfire_2012_2017 | head
> > >cat|FIRE_TYPE|OBJECTID|START_DATE|END_DATE|STATE|AREA_ha|PERIMETER_km
> > >v.db.select act_bushfire_2012_2017
> > >cat|OBJECTID|FIRE_TYPE|START_DATE|END_DATE|STATE|AREA_ha|PERIMETER_km
> > >only OBJECTID and FIRE_TYPE are shifted.
> > >Is there an easy way to reorder columns in the attribute table of a
> > >vector map?? I thought v.patch would match column names in the attr
> > >table...
> > >Thanks much in advance,
> > >Vero
> > grass-user mailing list
> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180523/7c4811fa/attachment.html>
