[GRASS-user] v.select: difference between overlap and crosses for atype=areas and btype=lines
Moritz Lennert mlennert at club.worldonline.be
Fri May 25 00:05:29 PDT 2018
Could someone explain the difference between overlap and crosses in
v.select for the case where atype is areas and btype is lines ?
Using the same data as ain and bin, I get:
517 areas with overlap
but
3846 areas with crosses
Moritz
