[GRASS-user] Grass GIS Temporary files too large
Francois Chartier fra.chartier at gmail.com
Wed May 23 18:09:51 PDT 2018
thanks a lot.  it seems I am might be on the right path with other
comments. I could having an issue with a too high resolution.
2018-05-23 8:03 GMT-04:00 Stefan Blumentrath <Stefan.Blumentrath at nina.no>:
> That is fine. If you have enough space, running on local SSD is your best
> option.
> Just wanted to make sure that not the external hard disk is the bottleneck…
> Cheers
> Stefan
> *From:* Francois Chartier <fra.chartier at gmail.com>
> *Sent:* onsdag 23. mai 2018 13.11
> *To:* Stefan Blumentrath <Stefan.Blumentrath at nina.no>
> *Cc:* Markus Neteler <neteler at osgeo.org>; GRASS user list <
> grass-user at lists.osgeo.org>
> *Subject:* Re: [GRASS-user] Grass GIS Temporary files too large
> just running on my laptop.  to run on external drive, do i need to move
> all the files on the external drive (copy and paste all grass files)?
> 2018-05-23 7:06 GMT-04:00 Stefan Blumentrath <Stefan.Blumentrath at nina.no>:
> Hi Francois,
> Are you running this on the 1TB external harddrive you mentioned
> (presumably USB connected)?
> That could decrease performance significantly…
> Cheers
> Stefan
> *From:* grass-user <grass-user-bounces at lists.osgeo.org> *On Behalf Of *Francois
> Chartier
> *Sent:* onsdag 23. mai 2018 13.01
> *To:* Markus Neteler <neteler at osgeo.org>
> *Cc:* GRASS user list <grass-user at lists.osgeo.org>
> Simulation ran all night with the 70 k points and still at 10%.  I reran
> to get the error message but still not there yet.
> 2018-05-22 13:55 GMT-04:00 Markus Neteler <neteler at osgeo.org>:
> On Mon, May 21, 2018 at 8:19 PM, Francois Chartier
> <fra.chartier at gmail.com> wrote:
> > Hi,
> > I am trying to run a 3D interpolation with 70k points.  When running
> > V.Vol.RST, the simulation runs out of memory for the Temp File on my
> > computer.
> Could you please post the error message?
> thanks
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180523/2f2465c4/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180523/2f2465c4/attachment-0001.png>
