[GRASS-user] v vol rst super slow
Moritz Lennert
mlennert at club.worldonline.be
Thu May 24 01:52:58 PDT 2018
On 24/05/18 04:05, Francois Chartier wrote:
> Thank you,
> v.vol.rst input=BHMat1All_May12 at Toronto wcolumn=cat dmin=5
> elevation=may23trial
> it would appear to have worked. I changed the resolution to 200 m
> horizontally and 5 m for z using g.region as a trial.
Watch out: according to the info below, your horizontal resolution is
around 500, not 200.
FYI, if you want to define your region's extension with a vector, but
also want a fixed resolution (here 200 and 5), you can use the -a flag
of g.region to force g.region to use this precise resolution instead of
defining a resolution that is an exact divisor of the vector's extension.
Moritz
> | Layer: may23trial at Toronto Date: Wed May 23 21:46:30
> 2018 |
> | Mapset: Toronto Login of Creator: Francois
> Charti |
> | Location: Toronto
> | DataBase: C:\Users\Francois Chartier\Documents\grassdata
> | Title: may23trial
> | Units: none
> | Vertical unit: units
> | Timestamp: none
> | Type of Map: raster_3d Number of Categories: 0
> | Data Type: FCELL
> | Rows: 90
> | Columns: 85
> | Depths: 61
> | Total Cells: 466650
> | Total size: 853368 Bytes
> | Number of tiles: 64
> | Mean tile size: 13333 Bytes
> | Tile size in memory: 32384 Bytes
> | Number of tiles in x, y and z: 4, 4, 4
> | Dimension of a tile in x, y, z: 22, 23, 16
> | Projection: UTM (zone 17)
> | N: 4870795 S: 4825715 Res: 500.88888889
> | E: 651669 W: 609204 Res: 499.58823529
> | T: 352 B: 45 Res: 5.03278689
> | Range of data: min = -0.18226054 max = 32.72385025
> | Data Source:
> | Data Description:
> | generated by v.vol.rst
> | Comments:
> | v.vol.rst input="BHMat1All_May12 at Toronto" wcolumn="cat"
> tension=40. \ |
> | smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=5 wscale=1.0
> zscale=1.\ |
> | 0 elevation="may23trial"
> (Wed May 23 21:54:13 2018) Command finished (0 sec)
> 2018-05-23 21:42 GMT-04:00 Anna Petrášová <kratochanna at gmail.com
> <mailto:kratochanna at gmail.com>>:
> On Wed, May 23, 2018 at 9:02 PM, Francois Chartier
> <fra.chartier at gmail.com <mailto:fra.chartier at gmail.com>> wrote:
> > How do you change the resolution to something coarser?
> With g.region, res= is horizontal and tbres= is vertical resolution,
> e.g:
> g.region res=200 tbres=200 -p3
> > 2018-05-23 15:30 GMT-04:00 Markus Metz
> <markus.metz.giswork at gmail.com <mailto:markus.metz.giswork at gmail.com>>:
> >> On Wed, May 23, 2018 at 1:09 PM, Francois Chartier
> >> > see below
> >> > g.region -3p
> >> > projection: 1 (UTM)
> >> > zone: 17
> >> > datum: nad83
> >> > ellipsoid: grs80
> >> > north: 4870795
> >> > south: 4825715
> >> > west: 609204
> >> > east: 651669
> >> > top: 352.00000000
> >> > bottom: 45.00000000
> >> > nsres: 5
> >> > nsres3: 5
> >> > ewres: 5
> >> > ewres3: 5
> >> > tbres: 1
> >> > rows: 9016
> >> > rows3: 9016
> >> > cols: 8493
> >> > cols3: 8493
> >> > depths: 307
> >> > cells: 76572888
> >> > cells3: 23507876616
> >> > for v.vol.rst command line - i am not sure where you get this
> so i just
> >> > restarted the simulation.
> >> > Wed May 23 07:07:59 2018)
> >> > v.vol.rst input=BHMat1All_May12 at Toronto wcolumn=cat dmin=0.1
> >> > 25 records selected from table
> >> > Processing all selected output files will require 0 bytes of
> disk space
> >> > for temp files
> >> > WARNING: Points are more dense than specified 'DMIN'--ignored
> 65 points
> >> > (remain 76822)
> >> > WARNING: Unable to create <(null)> raster map without
> cross_input raster
> >> > map being specified
> >> > v.info <http://v.info>
> >> > (Wed May 23 07:06:24 2018)
> >> > v.info <http://v.info> map=BHMat1All_May12 at Toronto
> >> > | Mapset: Toronto
> >> > | Location: Toronto
> >> > | Database: C:\Users\Francois Chartier\Documents\grassdata
> >> > | Title:
> >> > | Map scale: 1:1
> >> > | Name of creator: Francois Chartier
> >> > | Organization:
> >> > | Source date: Sat May 12 15:45:44 2018
> >> > | Timestamp (first layer): none
> >> > | Map format: native
> >> > | Type of map: vector (level: 2)
> >> > | Number of points: 76887 Number of
> centroids: 0
> >> > | Number of lines: 0 Number of
> boundaries: 0
> >> > | Number of areas: 0 Number of
> islands: 0
> >> > | Number of faces: 0 Number of
> kernels: 0
> >> > | Number of volumes: 0 Number of holes:
> 0
> >> > | Map is 3D: Yes
> >> > | Number of dblinks: 1
> >> > | E: 651669 W: 609204
> >> > | B: 45 T: 352
> >> > | Digitization threshold: 0
> >> > | Comment:
> >> > (Wed May 23 07:06:24 2018) Command finished (0 sec)
> >> The current target resolutions of
> >> nsres3: 5
> >> ewres3: 5
> >> tbres: 1
> >> are much too high for the given extents and the coverage of the
> input
> >> points
> >> According to the output of v.info <http://v.info>, a point
> covers on average about 7643645
> >> cubic meters which corresponds to voxels with edge length of
> about 200
> >> meters. Therefore a good starting point would be a 3D region with
> >> resolutions in all 3 dimensions of 200 meter. If the results
> make sense, the
> >> resolutions can be slowly increased.
> >> Markus M
> >> > 2018-05-23 6:07 GMT-04:00 Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>:
> >> >> Hi François,
> >> >> Please keep all discussions on the list.
> >> >> On 23/05/18 02:26, Francois Chartier wrote:
> >> >>> Hi Moritz,
> >> >>> see below. seems like i have 6M cells
> >> >>> projection: 1 (UTM)
> >> >>> zone: 17
> >> >>> datum: nad83
> >> >>> ellipsoid: grs80
> >> >>> north: 4868980
> >> >>> south: 4829680
> >> >>> west: 609620
> >> >>> east: 651628
> >> >>> nsres: 5
> >> >>> ewres: 4.99976196
> >> >>> rows: 7860
> >> >>> cols: 8402
> >> >>> cells: 66039720
> >> >> Sorry, my fault: as you are interpolating in 3D we need the
> 3D region,
> >> >> so the output of 'g.region -3p'.
> >> >> And could you also provide us with:
> >> >> - the exact v.vol.rst command line you used
> >> >> - the output of v.info <http://v.info> on your point dataset
> >> >> Moritz
> >> >>> 2018-05-22 7:58 GMT-04:00 Moritz Lennert
> <mailto:mlennert at club.worldonline.be>>>:
> >> >>> Am 22. Mai 2018 04:35:13 MESZ schrieb Francois Chartier
> <mailto:fra.chartier at gmail.com <mailto:fra.chartier at gmail.com>>>:
> >> >>> >Hi,
> >> >>> >I am interpolating 2D data using V Vol RST. After 90
> min the
> >> >>> process
> >> >>> >progressed 15%, and I stopped it.
> >> >>> >There are approx 370 points, and it should not take
> this long.
> >> >>> I am
> >> >>> >not
> >> >>> >sure what I am doing incorrectly. I have set the
> g.region to
> >> >>> match the
> >> >>> >vector, and joined the vector attribute to the database.
> >> >>> What is the resolution of the region ?
> >> >>> Please provide the output of g.region -p.
> >> >>> Moritz
> >> > _______________________________________________
> >> > grass-user mailing list
> >> > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> >> > https://lists.osgeo.org/mailman/listinfo/grass-user
> <https://lists.osgeo.org/mailman/listinfo/grass-user>
