[GRASS-user] v vol rst super slow
Anna Petrášová
kratochanna at gmail.com
Wed May 23 19:12:44 PDT 2018
On Wed, May 23, 2018 at 10:05 PM, Francois Chartier
<fra.chartier at gmail.com> wrote:
> Thank you,
> v.vol.rst input=BHMat1All_May12 at Toronto wcolumn=cat dmin=5
> elevation=may23trial
> it would appear to have worked. I changed the resolution to 200 m
> horizontally and 5 m for z using g.region as a trial.
> now the big question is how do you see the data. I am able to view a 2D
> raster by changing the color scale but 3d raster is blank,
You can view it in 3D view, see https://youtu.be/CmK-fEyf2SY or use
r3.to.rast (https://grass.osgeo.org/grass74/manuals/r3.to.rast.html)
to slice it into a series of 2D rasters and view them.
> | Layer: may23trial at Toronto Date: Wed May 23 21:46:30 2018
> | Mapset: Toronto Login of Creator: Francois
> Charti |
> | Location: Toronto
> | DataBase: C:\Users\Francois Chartier\Documents\grassdata
> | Title: may23trial
> | Units: none
> | Vertical unit: units
> | Timestamp: none
> | Type of Map: raster_3d Number of Categories: 0
> | Data Type: FCELL
> | Rows: 90
> | Columns: 85
> | Depths: 61
> | Total Cells: 466650
> | Total size: 853368 Bytes
> | Number of tiles: 64
> | Mean tile size: 13333 Bytes
> | Tile size in memory: 32384 Bytes
> | Number of tiles in x, y and z: 4, 4, 4
> | Dimension of a tile in x, y, z: 22, 23, 16
> | Projection: UTM (zone 17)
> | N: 4870795 S: 4825715 Res: 500.88888889
> | E: 651669 W: 609204 Res: 499.58823529
> | T: 352 B: 45 Res: 5.03278689
> | Range of data: min = -0.18226054 max = 32.72385025
> | Data Source:
> | Data Description:
> | generated by v.vol.rst
> | Comments:
> | v.vol.rst input="BHMat1All_May12 at Toronto" wcolumn="cat" tension=40. \
> | smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=5 wscale=1.0 zscale=1.\
> | 0 elevation="may23trial"
> (Wed May 23 21:54:13 2018) Command finished (0 sec)
> 2018-05-23 21:42 GMT-04:00 Anna Petrášová <kratochanna at gmail.com>:
>> On Wed, May 23, 2018 at 9:02 PM, Francois Chartier
>> > How do you change the resolution to something coarser?
>> With g.region, res= is horizontal and tbres= is vertical resolution, e.g:
>> g.region res=200 tbres=200 -p3
>> > 2018-05-23 15:30 GMT-04:00 Markus Metz <markus.metz.giswork at gmail.com>:
>> >> On Wed, May 23, 2018 at 1:09 PM, Francois Chartier
>> >> > see below
>> >> > g.region -3p
>> >> > projection: 1 (UTM)
>> >> > zone: 17
>> >> > datum: nad83
>> >> > ellipsoid: grs80
>> >> > north: 4870795
>> >> > south: 4825715
>> >> > west: 609204
>> >> > east: 651669
>> >> > top: 352.00000000
>> >> > bottom: 45.00000000
>> >> > nsres: 5
>> >> > nsres3: 5
>> >> > ewres: 5
>> >> > ewres3: 5
>> >> > tbres: 1
>> >> > rows: 9016
>> >> > rows3: 9016
>> >> > cols: 8493
>> >> > cols3: 8493
>> >> > depths: 307
>> >> > cells: 76572888
>> >> > cells3: 23507876616
>> >> > for v.vol.rst command line - i am not sure where you get this so i
>> >> > just
>> >> > restarted the simulation.
>> >> > Wed May 23 07:07:59 2018)
>> >> > v.vol.rst input=BHMat1All_May12 at Toronto wcolumn=cat dmin=0.1
>> >> > 25 records selected from table
>> >> > Processing all selected output files will require 0 bytes of disk
>> >> > space
>> >> > for temp files
>> >> > WARNING: Points are more dense than specified 'DMIN'--ignored 65
>> >> > points
>> >> > (remain 76822)
>> >> > WARNING: Unable to create <(null)> raster map without cross_input
>> >> > raster
>> >> > map being specified
>> >> > v.info
>> >> > (Wed May 23 07:06:24 2018)
>> >> > v.info map=BHMat1All_May12 at Toronto
>> >> > | Mapset: Toronto
>> >> > | Location: Toronto
>> >> > | Database: C:\Users\Francois Chartier\Documents\grassdata
>> >> > | Title:
>> >> > | Map scale: 1:1
>> >> > | Name of creator: Francois Chartier
>> >> > | Organization:
>> >> > | Source date: Sat May 12 15:45:44 2018
>> >> > | Timestamp (first layer): none
>> >> > | Map format: native
>> >> > | Type of map: vector (level: 2)
>> >> > | Number of points: 76887 Number of centroids: 0
>> >> > | Number of lines: 0 Number of boundaries: 0
>> >> > | Number of areas: 0 Number of islands: 0
>> >> > | Number of faces: 0 Number of kernels: 0
>> >> > | Number of volumes: 0 Number of holes: 0
>> >> > | Map is 3D: Yes
>> >> > | Number of dblinks: 1
>> >> > | E: 651669 W: 609204
>> >> > | B: 45 T: 352
>> >> > | Digitization threshold: 0
>> >> > | Comment:
>> >> > (Wed May 23 07:06:24 2018) Command finished (0 sec)
>> >> The current target resolutions of
>> >> nsres3: 5
>> >> ewres3: 5
>> >> tbres: 1
>> >> are much too high for the given extents and the coverage of the input
>> >> points
>> >> According to the output of v.info, a point covers on average about
>> >> 7643645
>> >> cubic meters which corresponds to voxels with edge length of about 200
>> >> meters. Therefore a good starting point would be a 3D region with
>> >> resolutions in all 3 dimensions of 200 meter. If the results make
>> >> sense, the
>> >> resolutions can be slowly increased.
>> >> Markus M
>> >> > 2018-05-23 6:07 GMT-04:00 Moritz Lennert
>> >> > <mlennert at club.worldonline.be>:
>> >> >> Hi François,
>> >> >> Please keep all discussions on the list.
>> >> >> On 23/05/18 02:26, Francois Chartier wrote:
>> >> >>> Hi Moritz,
>> >> >>> see below. seems like i have 6M cells
>> >> >>> projection: 1 (UTM)
>> >> >>> zone: 17
>> >> >>> datum: nad83
>> >> >>> ellipsoid: grs80
>> >> >>> north: 4868980
>> >> >>> south: 4829680
>> >> >>> west: 609620
>> >> >>> east: 651628
>> >> >>> nsres: 5
>> >> >>> ewres: 4.99976196
>> >> >>> rows: 7860
>> >> >>> cols: 8402
>> >> >>> cells: 66039720
>> >> >> Sorry, my fault: as you are interpolating in 3D we need the 3D
>> >> >> region,
>> >> >> so the output of 'g.region -3p'.
>> >> >> And could you also provide us with:
>> >> >> - the exact v.vol.rst command line you used
>> >> >> - the output of v.info on your point dataset
>> >> >> Moritz
>> >> >>> 2018-05-22 7:58 GMT-04:00 Moritz Lennert
>> >> >>> <mailto:mlennert at club.worldonline.be>>:
>> >> >>> Am 22. Mai 2018 04:35:13 MESZ schrieb Francois Chartier
>> >> >>> <fra.chartier at gmail.com <mailto:fra.chartier at gmail.com>>:
>> >> >>> >Hi,
>> >> >>> >I am interpolating 2D data using V Vol RST. After 90 min the
>> >> >>> process
>> >> >>> >progressed 15%, and I stopped it.
>> >> >>> >There are approx 370 points, and it should not take this
>> >> >>> long.
>> >> >>> I am
>> >> >>> >not
>> >> >>> >sure what I am doing incorrectly. I have set the g.region to
>> >> >>> match the
>> >> >>> >vector, and joined the vector attribute to the database.
>> >> >>> What is the resolution of the region ?
>> >> >>> Please provide the output of g.region -p.
>> >> >>> Moritz
>> >> > _______________________________________________
>> >> > grass-user mailing list
>> >> > grass-user at lists.osgeo.org
>> >> > https://lists.osgeo.org/mailman/listinfo/grass-user
