[GRASS-user] v.select: difference between overlap and crosses for atype=areas and btype=lines
Markus Metz markus.metz.giswork at gmail.com
Fri May 25 10:45:46 PDT 2018
On Fri, May 25, 2018 at 4:43 PM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> On 25/05/18 09:05, Moritz Lennert wrote:
>> Hi,
>> Could someone explain the difference between overlap and crosses in
>> v.select for the case where atype is areas and btype is lines ?
>> Using the same data as ain and bin, I get:
>> 517 areas with overlap
>> but
>> 3846 areas with crosses
> Additional information:
> using 'intersects' I also get 3846 areas.
> Now I'm confused.
> Any hints ?
Any information from GEOS/JTS on the expected behaviour?
Markus M
> Moritz
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180525/732e1fd4/attachment.html>
