[GRASS-user] v.select: difference between overlap and crosses for atype=areas and btype=lines
Markus Metz markus.metz.giswork at gmail.com
Sat May 26 12:51:47 PDT 2018
On Fri, May 25, 2018 at 7:45 PM, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Fri, May 25, 2018 at 4:43 PM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> > On 25/05/18 09:05, Moritz Lennert wrote:
> >> Hi,
> >> Could someone explain the difference between overlap and crosses in
> >> v.select for the case where atype is areas and btype is lines ?
> >> Using the same data as ain and bin, I get:
> >> 517 areas with overlap
> >> but
> >> 3846 areas with crosses
> > Additional information:
> > using 'intersects' I also get 3846 areas.
> > Now I'm confused.
> > Any hints ?
> Any information from GEOS/JTS on the expected behaviour?
The theory behind these topological relations is explained in
https://en.wikipedia.org/wiki/DE-9IM
maybe that helps.
Markus M
> Markus M
> > Moritz
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180526/ba20ebee/attachment.html>
