[GRASS-user] 3D raster color coding
Francois Chartier
fra.chartier at gmail.com
Wed May 30 18:18:28 PDT 2018
I have created a 3D raster from soil properties with about 70K points, with
a* lot of help from the mailing list i must say*.
from the copy of the metadata of the 3d raster (below) it would confirm
that the 3D raster worked and the grid is populated with data.
I have copied below the r3.colors and assigned 'aspectcolr' as a trial.
Unfortunately in the Display window nothing shows up, whether in 2D or in
3D view. I do not know what i am doing incorrectly.
Once I am done and able to develop the 3D raster of the soil properties, I
will prepare a simple step by step for developing such a raster which may
be useful for others.
| Layer: BHALL_May24v2 at Toronto Date: Sun May 27 16:43:46 2018
| Mapset: Toronto Login of Creator: Francois
Charti |
| DataBase: C:\Users\Francois Chartier\Documents\grassdata
| Title: BHALL_May24v2
| Units: none
| Vertical unit: units
| Timestamp: none
| Type of Map: raster_3d Number of Categories: 0
| Data Type: FCELL
| Rows: 90
| Columns: 85
| Depths: 307
| Total Cells: 2348550
| Total size: 3180868 Bytes
| Number of tiles: 336
| Mean tile size: 9466 Bytes
| Tile size in memory: 30420 Bytes
| Number of tiles in x, y and z: 6, 7, 8
| Dimension of a tile in x, y, z: 15, 13, 39
| Projection: UTM (zone 17)
| N: 4870795 S: 4825715 Res: 500.88888889
| E: 651669 W: 609204 Res: 499.58823529
| T: 352 B: 45 Res: 1
| Range of data: min = -8.99099445 max = 33.89262009
| Data Source:
| Data Description:
| generated by v.vol.rst
| Comments:
| v.vol.rst input="BHMat1All_May12 at Toronto" wcolumn="cat" tension=40.
| smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=2 wscale=1.0
zscale=1.\ |
| 0 elevation="BHALL_May24v2"
(Wed May 30 21:11:59 2018) Command finished (0 sec)
(Wed May 30 21:10:02 2018)
r3.colors map=BHALL_May24v2 at Toronto color=aspectcolr
Color table for raster3d map <BHALL_May24v2 at Toronto> set to 'aspectcolr'
(Wed May 30 21:10:03 2018) Command finished (0 sec)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180530/7bd0ae14/attachment.html>
