[GRASS-user] v.color takes a long time for 2E6 records
Mehrdad Varedi varedi at gmail.com
Thu May 31 07:57:27 PDT 2018
Hi Markus,
I tried the db.connect -p and found that the database driver is SQLite.
(Thu May 31 10:53:07 2018)
db.connect -p
driver: sqlite
database:
F:\Projects-Analysis\GRASSData\SWOntarioTestSites\Waterlix\sqlite\sqlite.db
schema:
group:
(Thu May 31 10:53:07 2018) Command finished (0 sec)
Does anything else cause the issue?
Thanks for your help.
Mehrdad
On Thu, May 31, 2018 at 9:13 AM, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Wed, May 30, 2018 at 11:50 PM, Mehrdad Varedi <varedi at gmail.com> wrote:
> > Hi Everyone,
> > When using v.color on a map with 2 Million points, it takes more than 24
> hours (I guess the last time it took near 40 hours). The CPU is busy less
> than 20% on a 8 core machine and a lot of memory is available (50% at least
> is empty out of the 16 GB). Is there a way that I could accelerate the
> processing? Is it normal at all?
> A reason could be that the vector uses dbf as database driver. Database
> drivers other than dbf can make use of an index, therefore you could verify
> the database driver for WM195 with v.db.connect -p
> If the vector uses dbf, you can switch to the default sqlite driver with
> db.connect -d
> then verify with db.connect -p
> now make a copy of the vector and try again v.colors.
> HTH,
> Markus M
> > Here is the command I am using:
> > v.colors -c --verbose map=WM195 at Waterlix use=attr column=BRProbH
> color=gyr rgb_column=ColorH
> > Thanks for your help in advance,
> > Mehrdad
> > Mehrdad Varedi
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
Mehrdad Varedi
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180531/03a8eed5/attachment.html>
