[GRASS-user] v.to.db: values not added to table
Rich Shepard
rshepard at appl-ecosys.com
Fri Nov 2 12:55:48 PDT 2018
Using 7.7.svn and pg.connect -p reporting the database is postgres.
The table 'stations' currently has six attribute columns: site_nbr,
site_name, lat, lon, easting, and northing (the last two added using psql.)
To add easting and northing values to the table I ran v.to.db with this
result:
v.to.db map=stations op=coor col=easting,northing units=meters --o
WARNING: Values in column <easting> will be overwritten
WARNING: Values in column <northing> will be overwritten
Reading features...
100%
Updating database...
100%
82 categories read from vector map (layer 1)
82 records selected from table (layer 1)
82 categories read from vector map exist in selection from table
82 records updated/inserted (layer 1)
which looks encouaging. But, when I query the database there are no values
in the easting and northing columns:
# select * from stations limit 5;
site_nbr | site_name | lon |
lat | easting | northing
10332 | Willamette R. at SP&S RR Bridge (Portland) | -122.747500 | 4
5.577944 | |
10335 | Willamette R. at Staff Jennings Marina | -122.664139 | 4
5.466111 | |
10339 | Willamette R. at Canby Ferry | -122.690722 | 4
5.300333 | |
10340 | Willamette R. at I-5 (Wilsonville) | -122.768194 | 4
5.291944 | |
10342 | Willamette R. at Hwy 219 (new Newberg bridge) | -122.942361 | 4
5.267639 | |
(5 rows)
What have I missed here?
TIA,
Rich
