[GRASS-user] v.to.db: values not added to table
st_kiefer at web.de
st_kiefer at web.de
Mon Nov 5 00:10:41 PST 2018
Hi Rich,
do you still have trouble filling the columns? You probably should give also the type of the feature for the query, like type=point.
v.to.db map=stations op=coor like type=point col=easting,northing units=meters --o
If this is not successfull you might have to (re)build topology (v. clean, v.build).
Regards.
Stefan
> Rich Shepard <rshepard at appl-ecosys.com> hat am 2. November 2018 um 20:55 geschrieben:
> Using 7.7.svn and pg.connect -p reporting the database is postgres.
> The table 'stations' currently has six attribute columns: site_nbr,
> site_name, lat, lon, easting, and northing (the last two added using psql.)
> To add easting and northing values to the table I ran v.to.db with this
> result:
> v.to.db map=stations op=coor col=easting,northing units=meters --o
> WARNING: Values in column <easting> will be overwritten
> WARNING: Values in column <northing> will be overwritten
> Reading features...
> 100%
> Updating database...
> 100%
> 82 categories read from vector map (layer 1)
> 82 records selected from table (layer 1)
> 82 categories read from vector map exist in selection from table
> 82 records updated/inserted (layer 1)
> which looks encouaging. But, when I query the database there are no values
> in the easting and northing columns:
> # select * from stations limit 5;
> site_nbr | site_name | lon |
> lat | easting | northing
> 10332 | Willamette R. at SP&S RR Bridge (Portland) | -122.747500 | 4
> 5.577944 | |
> 10335 | Willamette R. at Staff Jennings Marina | -122.664139 | 4
> 5.466111 | |
> 10339 | Willamette R. at Canby Ferry | -122.690722 | 4
> 5.300333 | |
> 10340 | Willamette R. at I-5 (Wilsonville) | -122.768194 | 4
> 5.291944 | |
> 10342 | Willamette R. at Hwy 219 (new Newberg bridge) | -122.942361 | 4
> 5.267639 | |
> (5 rows)
> What have I missed here?
> TIA,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
