[GRASS-user] v.vol.rst - DMIN and Segment Size
Francois Chartier
fra.chartier at gmail.com
Fri Nov 9 04:16:23 PST 2018
does anybody know how to resolve this?
On Thu, Nov 8, 2018, 06:23 Francois Chartier <fra.chartier at gmail.com wrote:
> Hi,
> I am trying to use V.VOL.RST to interpolate particle size for soil
> samples. i obtain the error message to increase DMin. unfortunately i
> have a data point every meter vertically and a total of 190K. if grass is
> asking to increase DMIN, which i have increased to 30 m to try to see if
> this was the pb, can I resolve this by reducing the Segment size?
> * COMMAND OUTPUT*
> (Thu Nov 08 06:17:32 2018) Command finished (10 sec)
> (Thu Nov 08 06:20:40 2018)
> v.vol.rst input=geotechNov8 at Toronto wcolumn=dbl_2 npmin=50 npmax=200
> dmin=30 elevation=Geotech3DNov8
> 188692 records selected from table
> WARNING: Some points outside of region -- will ignore...
> ERROR: Points are too concentrated -- please increase DMIN
> (Thu Nov 08 06:20:51 2018) Command finished (10 sec)
> *METADATA*
> Thu Nov 08 06:11:32 2018) Command finished (0 sec)
> (Thu Nov 08 06:19:17 2018)
> v.info map=geotechNov8 at Toronto
> | Mapset: Toronto
> | Location: Toronto
> | Database: C:\Users\Francois Chartier\Documents\grassdata
> | Title:
> | Map scale: 1:1
> | Name of creator: Francois Chartier
> | Organization:
> | Source date: Thu Nov 08 06:06:56 2018
> | Timestamp (first layer): none
> | Map format: native
> | Type of map: vector (level: 2)
> | Number of points: 188692 Number of centroids: 0
> | Number of lines: 0 Number of boundaries: 0
> | Number of areas: 0 Number of islands: 0
> | Number of faces: 0 Number of kernels: 0
> | Number of volumes: 0 Number of holes: 0
> | Map is 3D: Yes
> | Number of dblinks: 1
> | Projection: UTM (zone 17)
> | N: 4870782 S: 4825713
> | E: 651697 W: 609201
> | B: 0 T: 352
> | Digitization threshold: 0
> | Comment:
> (Thu Nov 08 06:19:18 2018) Command finished (0 sec)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181109/3401d7f2/attachment-0001.html>
