[GRASS-user] v.vol.rst - DMIN and Segment Size
Francois Chartier fra.chartier at gmail.com
Tue Nov 13 16:28:56 PST 2018
v.vol.rst starts working when npmin is 100 m or more.  I dont believe that
this algorythm only works with data points spaced by 100 m that does not
make sense.  is there a max total number for a dataset? is it because i
have too few rows and columns?
see metadata below.  i also showed a lower dmin of 0.9.  g.region is
printed at the end of the email
 |   Type of Map:  raster_3d            Number of Categories: 0
 |   Data Type:    FCELL
 |   Rows:         90
 |   Columns:      85
 |   Depths:       2
 |   Total Cells:  15300
 |   Total size:           48229 Bytes
 |   Number of tiles:      4
 |   Mean tile size:       12057 Bytes
 |   Tile size in memory:  15480 Bytes
 |   Number of tiles in x, y and  z:   2, 2, 1
 |   Dimension of a tile in x, y, z:   43, 45, 2
 |        Projection: UTM (zone 17)
 |            N:    4870782    S:    4825713   Res: 500.76666667
 |            E:     651697    W:     609201   Res: 499.95294118
 |            T:        352    B:          0   Res:   176
 |   Range of data:   min = -1.17721057 max = 89.22615051
 |   Data Source:
 |   Data Description:
 |    generated by v.vol.rst
 |   Comments:
 |    v.vol.rst --overwrite input="geotechNov8 at Toronto" wcolumn="dbl_2"
te\   |
 |    nsion=40. smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=100
wscale=1\   |
 |    .0 zscale=1.0 elevation="geotechnov8"
(Tue Nov 13 19:18:12 2018) Command finished (0 sec)
*i have also tried with low dmin of 0.9 m:*
(Tue Nov 13 19:22:49 2018)
v.vol.rst --overwrite input=geotechNov8 at Toronto wcolumn=dbl_2 npmin=60
npmax=100 dmin=0.9 elevation=geotechnov13
188692 records selected from table
WARNING: Some points outside of region -- will ignore...
ERROR: Points are too concentrated -- please increase DMIN
(Tue Nov 13 19:23:00 2018) Command finished (10 sec)
METADATA of Vector points
Thu Nov 08 06:06:56 2018                                  |
 | Timestamp (first layer): none
 | Map format:      native
 |   Type of map: vector (level: 2)
 |   Number of points:       188692          Number of centroids:  0
 |   Number of lines:        0               Number of boundaries: 0
 |   Number of areas:        0               Number of islands:    0
 |   Number of faces:        0               Number of kernels:    0
 |   Number of volumes:      0               Number of holes:      0
 |   Map is 3D:              Yes
 |   Number of dblinks:      1
 |               E:            651697    W:            609201
 |               B:                 0    T:               352
 |   Digitization threshold: 0
 |   Comment:
(Tue Nov 13 19:25:30 2018) Command finished (0 sec)
g.region - p
projection: 1 (UTM)
zone:       17
datum:      nad83
ellipsoid:  grs80
north:      4862000
south:      4825700
west:       609200
east:       651700
nsres:      10
ewres:      10
rows:       3630
cols:       4250
cells:      15427500
Le ven. 9 nov. 2018 à 07:16, Francois Chartier <fra.chartier at gmail.com> a
écrit :
> does anybody know how to resolve this?
> On Thu, Nov 8, 2018, 06:23 Francois Chartier <fra.chartier at gmail.com
> wrote:
>> Hi,
>> I am trying to use V.VOL.RST to interpolate particle size for soil
>> samples.   i obtain the error message to increase DMin. unfortunately i
>> have a data point every meter vertically and a total of 190K.  if grass is
>> asking to increase DMIN, which i have increased to 30 m to try to see if
>> this was the pb, can I resolve this by reducing the Segment size?
>> * COMMAND OUTPUT*
>> (Thu Nov 08 06:17:32 2018) Command finished (10 sec)
>> (Thu Nov 08 06:20:40 2018)
>> v.vol.rst input=geotechNov8 at Toronto wcolumn=dbl_2 npmin=50 npmax=200
>> dmin=30 elevation=Geotech3DNov8
>> (Thu Nov 08 06:20:51 2018) Command finished (10 sec)
>> *METADATA*
>> Thu Nov 08 06:11:32 2018) Command finished (0 sec)
>> (Thu Nov 08 06:19:17 2018)
>> v.info map=geotechNov8 at Toronto
>>  | Mapset:          Toronto
>>  | Location:        Toronto
>>  | Database:        C:\Users\Francois Chartier\Documents\grassdata
>>  | Title:
>>  | Map scale:       1:1
>>  | Name of creator: Francois Chartier
>>  | Organization:
>>  | Source date:     Thu Nov 08 06:06:56 2018
>>  | Map format:      native
>>  |   Map is 3D:              Yes
>>  |               E:            651697    W:            609201
>>  |               B:                 0    T:               352
>>  |   Comment:
>> (Thu Nov 08 06:19:18 2018) Command finished (0 sec)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181113/7a5604b9/attachment-0001.html>
