[GRASS-user] patching vectors - some are not patched
Markus Metz markus.metz.giswork at gmail.com
Mon Nov 19 07:32:18 PST 2018
On Mon, Nov 19, 2018 at 12:20 PM Ken Mankoff <mankoff at gmail.com> wrote:
> Hi List,
> On 2018-11-19 at 08:26 +0100, Ken Mankoff <mankoff at gmail.com> wrote:
> > I'm having trouble getting v.patch to patch some vectors. I've tested
> > this on Linux grass 7.4.0 (default Ubuntu 18.04 version) and SVN trunk
> > from this evening.
> It appears I can get the patched vectors to work by using v.clean. In
this way, the "basin" vector accumulates the "b" vectors generated from the
"basin" raster.
> r.mapcalc "basin = if(basin, ${count}, null())" --o
> r.to.vect -v input=basin output=b type=area --o
> v.patch -a input=b output=basin --o
> v.clean in=basin out=basin_clean0 tool=break,rmdupl --o
> v.clean in=basin_clean0 out=basin_clean1 tool=snap,break,rmdupl --o
you can also clean the patched vector with
v.clean tool=bpol,rmdupl,break,rmdupl -c
it could be a bit faster
Markus M
> g.rename vector=basin_clean1,basin --o
>   -k.
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181119/ad2dd417/attachment.html>
