[GRASS-user] edit vector with wxGUI
    Frank David
    frank.david at geophom.fr
    Wed Nov 21 10:09:17 PST 2018
Le 21/11/2018 à 18:42, Rich Shepard a écrit :
> On Wed, 21 Nov 2018, Frank David wrote:
>> I can not use the vector editing interface wxGUI, especially for moving
>> and deleting points. I set the layer in edition mode. I can add points,
>> but cannot move or delete them. The GUI button looks like line vertex
>> edition rather than isolated point. Thank you for your help. Regards,
> Frank,
>   It takes a while to figure out just how to edit vector maps with the
> GUI.
> What I do is select a bunch of points to delete, save and close the GUI,
> then re-open it. The points are gone. This with 7.7.svn. My
> experiences with
> it have done what I needed even though the process was not as simple
> as it
> could be.
>   Play with it and you'll find a rhythm that works for what you need
> to do.
> Regards,
> Rich
Thanks Rich,
it's mostly to move the points that I need. It's a shame because the
interface could be useful if it was functional. Cheers, Frank
