[GRASS-user] buffer to wrap points
    Daniel Victoria
    daniel.victoria at gmail.com
    Thu Nov 29 04:40:13 PST 2018
Or are you looking at a way to wrap all points? Like v.hull [1]
There is also an addon for concave hull [2]
Cheers
[1] - https://grass.osgeo.org/grass74/manuals/v.hull.html
[2] - https://grass.osgeo.org/grass74/manuals/addons/v.concave.hull.html
On Thu, Nov 29, 2018 at 10:10 AM Ken Mankoff <mankoff at gmail.com> wrote:
> Hi Frank,
> On 2018-11-29 at 12:46 +0100, Frank David <frank.david at geophom.fr> wrote:
> > I did not find in v.buffer the way to create a common buffer on points
> > if I want the buffer wraps all my points. Is there any tricks ?
> Can you explain what you did and what happened and what you expected to
> happen? There is a section in the v.buffer man page "Circles around input
> points" that provides an example. Does this work for you?
>   -k.
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181129/66371a10/attachment.html>
