[GRASS-user] buffer to wrap points
    Frank David
    frank.david at geophom.fr
    Thu Nov 29 05:36:54 PST 2018
Thank you,
Yes, actually it was what I was looking for...
Regards,
Frank
Le 29/11/2018 à 13:40, Daniel Victoria a écrit :
> Or are you looking at a way to wrap all points? Like v.hull [1]
> There is also an addon for concave hull [2]
> Cheers
> [1] - https://grass.osgeo.org/grass74/manuals/v.hull.html
> [2] - https://grass.osgeo.org/grass74/manuals/addons/v.concave.hull.html
> On Thu, Nov 29, 2018 at 10:10 AM Ken Mankoff <mankoff at gmail.com
> <mailto:mankoff at gmail.com>> wrote:
>     Hi Frank,
>     On 2018-11-29 at 12:46 +0100, Frank David <frank.david at geophom.fr
>     <mailto:frank.david at geophom.fr>> wrote:
>     > I did not find in v.buffer the way to create a common buffer on
>     points
>     > if I want the buffer wraps all my points. Is there any tricks ?
>     Can you explain what you did and what happened and what you
>     expected to happen? There is a section in the v.buffer man page
>     "Circles around input points" that provides an example. Does this
>     work for you?
>       -k.
>     _______________________________________________
>     grass-user mailing list
>     grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/grass-user
