[GRASS-user] v. vol. rst tension parameters
Francois Chartier fra.chartier at gmail.com
Fri Nov 30 09:33:47 PST 2018
Hi
with a 3d data set and with variable density of dat points, if i want to
interpolate a property far away where there are no data points, how does
the tension parameters affect the Search Radius?  is there a way to define
similar to a semi variogram for the search distance?
also my data set is strongly correlate vertically with some abrupt changes
(soil borehole information) and data points are very dense along bh, but
very soarse between bh locations.  is there a way to apply different
tension parameters vertically from horizontally?
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181130/6a0b51ca/attachment.html>
