[GRASS-user] How to get the area of a polygon in a layer
Kalindu Perera kkc199408 at gmail.com
Mon Oct 15 03:31:38 PDT 2018
Dear Nikos,
We have used r.ros and r.spread commands for getting the wildfire
simulation.
After that, the output from the r.spread command is spread_time_observed
layer(This is the output from the simulation)
We use that layer as the input layer for the r.surf.area command.
We got many area outputs from that command output and couldn't identify
what area gives the area of the "burned" area
* I have attached the output from running r.surf.area command as an
attachment.
** Another question how we can extract only the "burned" area from the
spread_time_observed layer?
Thanks a lot for the quick reply
Looking forward to more knowledge
Best Regards
Kalindu Perera
On Mon, 15 Oct 2018 at 15:07, Nikos Alexandris <nik at nikosalexandris.net>
wrote:
> * Kalindu Perera <kkc199408 at gmail.com> [2018-10-15 13:28:15 +0530]:
> >Dear all,
> >We are doing wildfire simulation in Grass GIS. We need to compare the area
> >of 2 wildfire spreads after wildfire simulation ran. We tried to calculate
> >the area of the spread using r.surf.area module. But we couldn't identify
> >which is the area of the simulation from areas given from that. Could
> >anyone tell us how to get an area from spread like this?
> Dear Kalindu,
> please post exact commands you already tried.
> What are the simulation output maps?
> Fitst, what does `r.category` and `r.report` return when used for
> simulation
> maps?
> Then, maybe you need to "extract", each time, the "burned" area, then
> use `r.surf.area` on it?
> Nikos
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181015/b6d4b11f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181015/b6d4b11f/attachment-0001.png>
