[GRASS-user] Cannot display raster maps
Rich Shepard rshepard at appl-ecosys.com
Tue Oct 16 12:19:19 PDT 2018
On Tue, 16 Oct 2018, Markus Neteler wrote:
> The correct order would be:
> make distclean; svn update; configure; make; make install
> Note the distclean in the _beginning_ to compile from a clean source tree.
> Just to be sure better have it first.
Markus,
   That's what I wrote. After running svn up I run configure; make; make
install; make distclean. This leaves the source tree clean prior to the next
svn up.
   Whether I run make distclean after installing the latest release, or just
before the next svn up should not matter. The directory ~/gis/grass/grass7_trunk/
is in the same state. I've been doing this for quite a few years and only
yesterday did this display error show up.
> Probably (cannot say right now) the latest parser change is causing
> troubles. Currently being investigated...
   Let me know if I can test changes on my installation.
Best regards,
Rich
