[GRASS-user] i.segment and i.segment.stats errors
Moritz Lennert
mlennert at club.worldonline.be
Wed Oct 17 09:47:02 PDT 2018
On 17/10/18 15:39, Jamille Haarloo wrote:
> Alright. Just tried, but got an old error back again. Also when
> reinstalling r.object.geometry got 'ERROR: File is not a zip file'
> i.segment.stats -n map=SegW24IDM4DV4 at LUP1
> rasters=DV2 at LUP1,DV4 at LUP1,IDM2 at LUP1,IDM4 at LUP1,W2 at LUP1,W4 at LUP1
> raster_statistics=variance,coeff_var,first_quart,median,third_quart,perc_90
> area_measures=compact_circle csvfile=Z:\nStats_SegW24IDM4DV4_17okt18
> vectormap=nvSegW24IDM4DV4 processes=4
> Calculating geometry statistics...
> Traceback (most recent call last):
> File "C:\Users\haarlooj\AppData\Roaming\GRASS7\addons/scri
> pts/i.segment.stats.py <http://i.segment.stats.py>", line 371, in <module>
> main()
> pts/i.segment.stats.py <http://i.segment.stats.py>", line 220, in main
> quiet=True)
> File "C:\PROGRA~1\QGIS21~1.0\apps\grass\grass-7.0.4\etc\py
> thon\grass\script\core.py", line 395, in run_command
> return handle_errors(returncode, returncode, args,
> kwargs)
> thon\grass\script\core.py", line 313, in handle_errors
> returncode=returncode)
> grass.exceptions.CalledModuleError: Module run None
> ['r.object.geometry', '--o', '--q',
> 'output=Z:\\GRASS_GIS/Cottica_LUP/LUP1/.tmp/unknown/7508.0',
> 'input=SegW24IDM4DV4 at LUP1'] ended with error
> Process ended with non-zero return code -1073741515. See
> errors in the (error) output.
> (Wed Oct 17 10:33:05 2018) Command finished (0 sec)
> g.extension r.object.geometry
> WARNING: Extension <r.object.geometry> already installed. Re-installing...
> Downloading precompiled GRASS Addons <r.object.geometry>...
> ERROR: File is not a zip file:
> http://wingrass.fsv.cvut.cz/grass70/x86_64/addons/grass-7.0.4/r.object.geometry.zip
> (Wed Oct 17 10:32:54 2018) Command finished (1 sec)
You seem to be using a very old version of GRASS: 7.0.4. There are no
addons available for Windows for that version. The official last release
of the 7.0 line was 7.0.6 and addons are available for that.
But I would really recommend that you work at least with the current
stable version 7.4.1 (soon 7.4.2) or even with a newer version.
Moritz
