[GRASS-user] i.segment and i.segment.stats errors
Jamille Haarloo j.r.haarloo at gmail.com
Wed Oct 17 10:15:48 PDT 2018
Yes, I noticed as other modules weren't working either. Stupid..
Just got the results with 7.6 and some "nan" values again.
Calculating geometry statistics...
Calculating statistics for raster maps...
Calculating neighborhood statistics...
Creating output vector map...
ERROR: Error while executing: 'INSERT INTO segmstat_tmp_vect_8116 VALUES
(2744,
10.574609,0.000657937002497415,100.010348629312,0.0118722,0.0199653,0.037037,0.0532407,0.0149315167004704,-34.81817527835,-0.440972,-0.375,-0.315972,-0.232639,0.0147358775257243,26.7103955510257,0.370735,0.452658,0.53125,0.60625,0.00759147152076699,10.6500844056518,0.75,0.802083,0.875,0.927083,4.16169760046326,52.4687741848501,2,3,5,7,0.200221189871832,35.183683942494,1,1,2,2,8,13.216384625,8.62095260592,0.00227423524743,0.00305950083943,223.15170811,122.713529331,0.01689609075,0.0219202839649,0.022322058,0.0229396651236,0.029157736625,0.0250281412368,0.03936146125,0.0291593758381,0.00809150063926,0.00998894786878,nan,nan,0.000935102375,0.00149429712142,0.00332539875,0.00553672330287,0.0106704025,0.0177514942977,0.0168798225,0.0277037009502,0.0108558662204,0.00624210011282,36.7678730965,22.2897752507,0.29285125,0.180951460467,0.3513889,0.181596981702,0.41656925,0.180382131329,0.485690125,0.1830333289,0.0149007045801,0.018570035777,30.2038217327,26.3183888064,0.5921816125,0.417141476181,0.642181,0.380369094661,0.699914125,0.345038582134,0.744641,0.316999979767,194.557427777,313.451777334,43.4071398819,21.8790138711,15.0,20.8086520467,20.25,27.6258484033,25.875,34.2798683632,32.375,41.9402476745,164.772935658,278.214855266,39.6227650243,32.7809091847,12.375,19.1307180994,16.25,25.5673131166,21.0,32.3921286735,26.875,40.3622270818)'
  File "C:\Users\haarlooj\AppData\Roaming\GRASS7\addons/scri
pts/i.segment.stats.py", line 371, in <module>
    main()
pts/i.segment.stats.py", line 358, in main
    gscript.run_command('db.execute', input=insert_sql,
quiet=True)
  File "C:\Program Files\GRASS GIS
7.6.svn\etc\python\grass\script\core.py", line 423, in
run_command
    return handle_errors(returncode, returncode, args,
kwargs)
7.6.svn\etc\python\grass\script\core.py", line 334, in
handle_errors
    returncode=returncode)
grass.exceptions.CalledModuleError: Module run None
['db.execute', '--q', 'input=Z:\\GRASS_GIS\\Cottica_LUP\\LUP
1\\.tmp/unknown\\8116.1'] ended with error
Process ended with non-zero return code 1. See errors in the
(error) output.
(Wed Oct 17 13:55:43 2018) Command finished (90 min 41 sec)
On Wed, Oct 17, 2018 at 1:48 PM Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> On 17/10/18 15:39, Jamille Haarloo wrote:
> > Alright. Just tried, but got an old error back again. Also when
> > reinstalling r.object.geometry got 'ERROR: File is not a zip file'
> > i.segment.stats -n map=SegW24IDM4DV4 at LUP1
> > rasters=DV2 at LUP1,DV4 at LUP1,IDM2 at LUP1,IDM4 at LUP1,W2 at LUP1,W4 at LUP1
> raster_statistics=variance,coeff_var,first_quart,median,third_quart,perc_90
> > area_measures=compact_circle csvfile=Z:\nStats_SegW24IDM4DV4_17okt18
> > vectormap=nvSegW24IDM4DV4 processes=4
> > pts/i.segment.stats.py <http://i.segment.stats.py>", line 371, in
> <module>
> >      main()
> > pts/i.segment.stats.py <http://i.segment.stats.py>", line 220, in main
> >      quiet=True)
> >    File "C:\PROGRA~1\QGIS21~1.0\apps\grass\grass-7.0.4\etc\py
> > thon\grass\script\core.py", line 395, in run_command
> > kwargs)
> > thon\grass\script\core.py", line 313, in handle_errors
> > ['r.object.geometry', '--o', '--q',
> > 'output=Z:\\GRASS_GIS/Cottica_LUP/LUP1/.tmp/unknown/7508.0',
> > 'input=SegW24IDM4DV4 at LUP1'] ended with error
> > Process ended with non-zero return code -1073741515. See
> > errors in the (error) output.
> > (Wed Oct 17 10:33:05 2018) Command finished (0 sec)
> > g.extension r.object.geometry
> > WARNING: Extension <r.object.geometry> already installed.
> Re-installing...
> > Downloading precompiled GRASS Addons <r.object.geometry>...
> > ERROR: File is not a zip file:
> http://wingrass.fsv.cvut.cz/grass70/x86_64/addons/grass-7.0.4/r.object.geometry.zip
> > (Wed Oct 17 10:32:54 2018) Command finished (1 sec)
> You seem to be using a very old version of GRASS: 7.0.4. There are no
> addons available for Windows for that version. The official last release
> of the 7.0 line was 7.0.6 and addons are available for that.
> But I would really recommend that you work at least with the current
> stable version 7.4.1 (soon 7.4.2) or even with a newer version.
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181017/7abd44bd/attachment-0001.html>
