[GRASS-user] r.basin error
Helmut Kudrnovsky
hellik at web.de
Mon Oct 22 12:50:51 PDT 2018
pelempito wrote
> Thanks Helmut for your reply.
> Certainly having two areas is not a desirable result, but I am not sure if
> there is a problem with the DEM. One of the areas encompasses an isolated
> pixel, which in fact is the basin outlet. This polygon is connected
> diagonally with the other one, which is the main area of the basin. Is it
> an
> issue of the DEM? The picture below shows the DEM cropped in the basin
> area,
> as well as the polygons and the main channel:
> <http://osgeo-org.1560.x6.nabble.com/file/t368208/demcropped.jpg>
> Many of my basins have an outlet such as the one described above. Should I
> move the outlets to the main area? Such a solution would be a bit
> impractical. However, some basin outlets may fall on an isolated pixel,
> which may not be considered as an error.
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> grass-user mailing list
> grass-user at .osgeo
> https://lists.osgeo.org/mailman/listinfo/grass-user
"/home/jr/.grass7/addons/scripts/r.width.funct", line
125, in findint
z1, z2, f1, f2 = kl[int(Xf[0])][0], kl[int(Xf[0]-1)][0],
kl[int(Xf[0])][1], kl[int(Xf[0]-1)][1]
TypeError: only length-1 arrays can be converted to Python
scalars
maybe it's not an DEM issue.
looking on your error, the issue arises in r.width.funct.
Not checked the code, AFAIR there may be some instability if there are 2
polygones. Have look into the source.
Do you maybe have some finer DEM for this region to test?
best regards
Helmut
