[GRASS-user] ps.map
Frank David
frank.david at geophom.fr
Tue Oct 23 04:35:34 PDT 2018
Hello,
I can't succeed to scale my raster as I want in the map window with ps.map
I've tried :
# g.region vector=max_area_vector_map at my_dataset
maploc 1.0 1.0
or
# g.region n=7030981.0 s=6950949.0 e=755872.0 w=691504.0 rows=1067 cols=858
maploc 1.0 1.0
with and without scale instruction like "scale 1:300000", and The
scaling when I use the command line psmap is always the same...
One thing is strange, when i use g.gui.psmap it works (the map scale is
fine), but if I try to use the exported instruction file from
g.gui.psmap with command line "ps.map in=myfile.txt out=myfile.ps" it
does not export the same scale (see attached file). Like if g.gui.psmap
do something witch is not writing in the instruction file??
Any idea from where I'm wrong ?
Thank you for your help.
Frank
-------------- section suivante --------------
Une pièce jointe autre que texte a été nettoyée...
Nom: psmap-scale.jpg
Type: image/jpeg
Taille: 152476 octets
Desc: non disponible
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181023/e74582f1/attachment-0001.jpg>
