[GRASS-user] ps.map
Frank David
frank.david at geophom.fr
Wed Oct 24 07:55:36 PDT 2018
Hello all,
I notice that the same command does not produce the same result if I run
it from the shell or if I use the ps.map GUI.
From GUI, le scale/region of ps file is correct, and if I run from the
shell, the region/scale setting is not respected
the psmap file begin with the region settings :
# timestamp: 2018-10-23 12:18
# location: France_L93
# mapset: volkswind_beaurevoir
# page orientation: Portrait
# g.region vector=WOLKSWIND_Beaurevoir_AEE at volkswind_beaurevoir
Is anybody notice that ?
Regards,
Frank
Le 23/10/2018 à 13:35, Frank David a écrit :
> Hello,
> I can't succeed to scale my raster as I want in the map window with
> ps.map
> I've tried :
> # g.region vector=max_area_vector_map at my_dataset
> maploc 1.0 1.0
> or
> # g.region n=7030981.0 s=6950949.0 e=755872.0 w=691504.0 rows=1067
> cols=858
> maploc 1.0 1.0
> with and without scale instruction like "scale 1:300000", and The
> scaling when I use the command line psmap is always the same...
> One thing is strange, when i use g.gui.psmap it works (the map scale
> is fine), but if I try to use the exported instruction file from
> g.gui.psmap with command line "ps.map in=myfile.txt out=myfile.ps" it
> does not export the same scale (see attached file). Like if
> g.gui.psmap do something witch is not writing in the instruction file??
> Any idea from where I'm wrong ?
> Thank you for your help.
> Frank
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181024/a8fbc1c0/attachment.html>
