[GRASS-user] d.rast in python script
Stefan Blumentrath Stefan.Blumentrath at nina.no
Wed Oct 24 00:23:19 PDT 2018
Hei Nikos, Frank,
I opened an enhancement ticket, and asked to activate the "Add created map(s) into layer tree" also for addons:
https://trac.osgeo.org/grass/ticket/3686. No idea what changes this would require...
Would that cover your needs, Frank, or do you have a more interactive use in a python script in mind?
You can start a wx monitor (d.mon wx0) and add a map there, but I have not found a way to address the currently active Map Display ...
This would probably require additional function(s) in the Python libraries...?
Maybe this question is better asked at the developer list (thus I put grass-dev in CC).
Cheers
Stefan
Sent: onsdag 24. oktober 2018 08:26
To: Nikos Alexandris <nik at nikosalexandris.net>
Cc: Stefan Blumentrath <Stefan.Blumentrath at nina.no>; Laurent C. <lrntct at gmail.com>; GRASS user list <grass-user at lists.osgeo.org>
Subject: Re: [GRASS-user] d.rast in python script
Le 23/10/2018 à 23:26, Nikos Alexandris a écrit :
* Frank David <frank.david at geophom.fr><mailto:frank.david at geophom.fr> [2018-10-23 22:06:01 +0200]:
Thank you everybody for your help. Do you know why a run_command("d.rast"... in a python script is not enough to display a raster ? I don't understand why this command is so different.
Display a raster map where?
Nikos
In the active map display (and respective Layer manager) as d.rast do it with gui...
Frank
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181024/1440b29e/attachment-0001.html>
