[GRASS-user] d.rast in python script
Frank David
frank.david at geophom.fr
Wed Oct 24 01:48:14 PDT 2018
Stephan,
Your last message makes me search after G_OPT_OUTPUT. I had never
realized that this option makes the "add to tree layer" check box appear
on the script GUI.
All my scripts create rasters without G_OPT_OUTPUT option (because the
name of output are handled by the script itself) and so, without check
box. Using d.rast could keep interesting i think in order to select
witch one should be display or not, but for the moment I can (may be)
overtake that limitation by using the G_OPT_OUTPUT option (I will see).
Sorry for confusing. And thank you very much for your help. I let you
see if the ticket you had post is appropriate.
Cheers,
Frank
Le 24/10/2018 à 10:13, Stefan Blumentrath a écrit :
> Hi Frank,
> My guess is that the GRASS standard parser options [1] (e.g.
> G_OPT_R_OUTPUT, G_OPT_R_OUTPUTS,G_OPT_V_OUTPUT, …) would be used in
> order to determine what has to be / could be added to the map display…
> But I am no GUI dev, and cannot tell for sure, hope experts on that
> part of the code could chime in …
> And yes, I agree that a convenient function in the Python library for
> adding a map in the currently active layer manager would be a nice new
> feature (if it does not exist and I just overlooked it)…
> Maybe another ticket?...
> Cheers
> Stefan
> 1: https://grass.osgeo.org/grass74/manuals/parser_standard_options.html
> *From:*Frank David <frank.david at geophom.fr>
> *Sent:* onsdag 24. oktober 2018 09:35
> *To:* Stefan Blumentrath <Stefan.Blumentrath at nina.no>; Nikos
> Alexandris <nik at nikosalexandris.net>
> *Cc:* Laurent C. <lrntct at gmail.com>; GRASS user list
> <grass-user at lists.osgeo.org>; GRASS developers list
> (grass-dev at lists.osgeo.org) <grass-dev at lists.osgeo.org>
> *Subject:* Re: [GRASS-user] d.rast in python script
> Hi Stephan,
> Thank you for the ticket. One thing seems to me important. Some (of
> my) scripts can generate numerous rasters and one or two cumulative
> raster. I don't want to add base rasters but only the few cumulative.
> If the script GUI have a check box, how to make the choice between
> these I want to display and those I don't want ?
> For my point of view, the use of d.rast inside the script, as we do
> for all other grass command, should be possible, in order to display
> what we want to display.
> Cheers,
> Frank
> Le 24/10/2018 à 09:23, Stefan Blumentrath a écrit :
> Hei Nikos, Frank,
> I opened an enhancement ticket, and asked to activate the "Add
> created map(s) into layer tree" also for addons:
> https://trac.osgeo.org/grass/ticket/3686. No idea what changes
> this would require…
> Would that cover your needs, Frank, or do you have a more
> interactive use in a python script in mind?
> You can start a wx monitor (d.mon wx0) and add a map there, but I
> have not found a way to address the currently active Map Display …
> This would probably require additional function(s) in the Python
> libraries…?
> Maybe this question is better asked at the developer list (thus I
> put grass-dev in CC).
> Cheers
> Stefan
> <mailto:frank.david at geophom.fr>
> *Sent:* onsdag 24. oktober 2018 08:26
> *To:* Nikos Alexandris <nik at nikosalexandris.net>
> <mailto:nik at nikosalexandris.net>
> *Cc:* Stefan Blumentrath <Stefan.Blumentrath at nina.no>
> <mailto:Stefan.Blumentrath at nina.no>; Laurent C. <lrntct at gmail.com>
> <mailto:lrntct at gmail.com>; GRASS user list
> <grass-user at lists.osgeo.org> <mailto:grass-user at lists.osgeo.org>
> Le 23/10/2018 à 23:26, Nikos Alexandris a écrit :
> * Frank David <frank.david at geophom.fr>
> <mailto:frank.david at geophom.fr> [2018-10-23 22:06:01 +0200]:
> Thank you everybody for your help. Do you know why a
> run_command("d.rast"... in a python script is not enough
> to display a raster ? I don't understand why this command
> is so different.
> Display a raster map where?
> Nikos
> In the active map display (and respective Layer manager) as d.rast
> do it with gui...
> Frank
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181024/2fa74948/attachment-0001.html>
