[GRASS-user] Migrating to new RDBMS
Markus Metz
markus.metz.giswork at gmail.com
Tue Oct 30 14:01:32 PDT 2018
On Tue, Oct 30, 2018 at 9:41 PM Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> I started grass7.7.svn (r73623) and set db.connect to use driver=pg and
> database='willamette_river_hg'. Then I copied the vector files (g.copy
> vect=current_file,current_file_pg) per the migration instructions on the
> databaseintro manual page.
> Trying to run db.copy to add attribute tables to the database (except
for
> one that is already present) using a script with commands like this:
> db.copy from_driver=sqlite
from_database='$HOME/data/grassdata/willamette_basin/mercury/sqlite/sqlite.db'
from_table=all_species to_driver=pg to_database='willamette_river_hg'
to_table=all_species.pg
> (on a single line)
> this is the warning generated:
> WARNING: Unable to open database
> <$HOME/data/grassdata/willamette_basin/mercury/sqlite/sqlite.db>
> by driver <sqlite>
> dbmi: Protocol error
> Yet, I can view the attribute table for the vector map within grass.
> Should I run db.connect to the sqlite database at the top of the
script?
db.copy does not need db.connect. The reason for the error is that the
variable $HOME is not expanded because it is within single quotes. Use
double quotes instead of single quotes for the from_database argument and
it should work.
Markus M
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181030/3d314f48/attachment.html>
