[GRASS-user] Migrating to new RDBMS [RESOLVED]
Rich Shepard rshepard at appl-ecosys.com
Tue Oct 30 14:16:22 PDT 2018
On Tue, 30 Oct 2018, Markus Metz wrote:
> db.copy does not need db.connect. The reason for the error is that the
> variable $HOME is not expanded because it is within single quotes. Use
> double quotes instead of single quotes for the from_database argument and
> it should work.
Markus,
   I was thinking of working within grass rather than at the bash prompt.
You're right: I know the difference between double and single quotes but
blew it on this instance.
Thanks very much,
Rich
